I have two questions:
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
Is this enough to power for:
ASUS M4A87TD/USB3 AM3 AMD 870 SATA 6Gb/s USB 3.0 AMD Motherboard
Item #: N82E16813131651
AMD Phenom II X3 720 Black Edition Heka 2.8GHz Socket AM3 95W Triple-Core Processor HDZ720WFK3DGI - OEM
Item #: N82E16819103652
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Item #: N82E16820231277
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152181
Quite possibly 2 in RAID0
SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Item #: N82E16814102858
And would a Sonata II, with the power supply replaced with the above, be good enough to house the above (5770,which I read gets quite hot. Currently the Sonata only has the rear fan)?
