K krisfaye Distinguished Feb 18, 2011 1 0 18,510 Feb 18, 2011 #1 Hello, can you pleased help me to fix my pc. the problem is that when i plug the 4 pin atx 12v power cable it has no power at all.
O o1die Illustrious May 16, 2001 14,175 0 42,960 Feb 18, 2011 #2 You may have a short on the 4 pin connector or in one of the 4 pin power supply wires. I would try a different power supply first. Also be sure the cable isn't stretched putting pressure on the wires. This could cause a bad connection. Upvote 0 Downvote
davcon Judicious May 17, 2010 8,860 0 34,960 Feb 18, 2011 #3 What mobo? Some won't post with a 4pin they require an 8pin atx 12v lead. Upvote 0 Downvote
