Hey guys,
Long story short. Comcast drilled a hole in our server closet without using silicone at the end which apparently was leaking water into that room every time it rained.
The rainwater has been directly hitting our RAID enclosure thus explaining our recent server outages.
Now I replaced the enclosure with a Sans Digital 5 Bay esata model and everything seemed to be "alright" however I started noticing:
1) All drives are half yellow, half grey.
2) I used to have (4) drives (all 500gb WD) but now only (3) show up with the yellow/gray. (the (4th) drive is all gray)
3) "Restoring Redundancy" (I dont know what this exactly does) takes 16 Hours but every single time, somewhere down the line it disconnects. (I havent been able to successfully restore after 6 attempts)
4) All of our shared folders, User profiles disappear in network drives once the drive raid drives unmount and mount. (The drives still show up, but the files are empty. I remedied this by unsharing and then sharing the folders from the drive, but this has become an annoyance)
These are my main issues.
I believe drive (2) is the malignant drive out of the (3). However when I hot swap it with another HD, the drive (D disappears.
I have tried everything I possibly could from researching the web and through my old IT guy but nothing is working.
If anyone could help, it would be greatly appreciated.
More info:
Windows Server 2003
Sans Digital 5 Bay enclosure
WD 500GB Hard Drives
Using RAID 10
Sataraid5 Program
Thank you for your time.
Best.
More info:
Windows Server 2003
Using RAID 10
Sataraid5 Program
Best.
