omnisome :
Scan.co.uk
cclonline.com
ebuyer.com (The British Newegg equivalent)
play.com
These are some better options
it needs to be amazon even if other places are cheaper or better!
Good choice, fair processor. What do you use the computer for? Gaming? Business? etc..
I wanted a higher Phenom II X4 but the higher ones at amazon are 125W which are incompatible, also I thought a low wattage CPU would be good to keep the electricity costs and
heat down!
I decided I wanted a quad core with L3 cache, and 120 quid is about the maximum cost,
the above was the best I could find on www.amazon.co.uk
I dont use the computer for gaming, the usage is relatively undemanding, but I do watch DVD films and eventually will probably watch blueray films, but I'll wait for blueray film prices to come down a lot further. But it should be this same computer, thus I want to buy components which will be current say in 5 years time.
I wanted PS/2 mouse and keyboard connectors also, not all motherboards have those.
I wouldn't personally recommend Hitachi, I've had a bad experience with their drives failing. Have a look at Samsung and Western-Digital.
ok, I'll have a study of those. Actually I prefer the system drive to be lower capacity eg 120G as I try to keep data on external USB drives in order to access the data from my laptop. But as the 1tb drive was just 10 quid more than 500G I thought I'd go for that.
Ideally I would like to keep all data in the future on USB3 drives, huge capacity drives are mainly for backups, but I like to backup my laptop also, thus USB2 and USB3 are useful.
What resolution are you running at? And when do you, if you do, intend to upgrade?
I use HD res with an LG Flatron W2253TQ, not keen on this monitor as the touch controls are impossible, but it was the only affordable one I could find which was digital, full HD, tiltable and silent. There was a Packard Bell which had very noisy inbuilt transformer, the Samsung wasnt tiltable, and all the other affordable ones were either not digital or not HD. At that time it wasnt constrained to amazon, and I prefer to buy monitors on the high street, at PC World and Comet
the above LG was the only TFT which met all the criteria. I probably should have got the nontiltable Samsung as it was otherwise ideal.
I'm intending to buy the above components other than the Blueray either today or tomorrow!
I'll probably delay the blueray as the prices should keep coming down,
probably I wont get further SATA drives but will use USB3, the USB3 criteria is more important to me. To backup a 120G drive takes many hours, thus the USB3 speeds should speed things up.
2004 - That's 7 years old. I wouldn't recommend it.
QTEC - Bottom of the totem-pole, worst-brand-ever! Cheap and unstable PSUs[/quotemsg]
ok, I wont use that!
what do you think of the
CIT 550W Gold 12Cm Silent Atx Power Supply
from amazon?
but maybe I should go for 400W or lower, I've no idea about the power requirements.
or any other recommendations from www.amazon.co.uk, it needs to be from this URL even if its cheaper elsewhere!
I'm more interested in sophisticated functionality than speeds as such, eg quad core, L3 cache, 8G, USB3. Low wattage also interests me, but I want higher speeds for the USB3
as I prefer to do sectorwise backups of entire drives or volumes, and these can take a long time. The graphics side just needs to be reasonable, I'm more interested in the cost being say 50 quid: in the past I've bought gfx cards from bargains at places like Maplins high street store. I dont want to pay 120 quid or something for a gfx card, I prefer to get end of season bargains for that.
the inbuilt graphics tends to be unacceptably bad!
