Hey everyone, I was wondering if I could get some advice about building my own PC. I am planning on using ibuypower.com because I've never built my own and I dont want to screw it up. My friend told me to post here and list the parts with links to the specs pages. So are these parts going to be compatible with each other to minimize bottle necks?:
thermaltake v9 case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133071&cm_re=thermaltake_v9-_-11-133-071-_-Product
internal usb expansion system with blue tooth module
amd athlon II x4 635
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103702&Tpk=amd%20athlon%20ii%20x4%20635
liquid cpu cooling system with 120mm radiator (amd)
4 gb (2gb*2) corsair xms3 dominator w/ dhx technology (I think this is the right spec)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145256&cm_re=corsair_dominator_4gb-_-20-145-256-_-Product
NVIDIA Geforce gts 250 - 1gb (some major brand, generic i guess)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130538&cm_re=nvidia_geforce_gts_250_1gb-_-14-130-538-_-Product
Gigabyte GA-770T-USB3--AMD770 (usb 3.0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128431&cm_re=gigabyte_ga-770t-_-13-128-431-_-Product
700 watt power supply SLI ready
500 gb primary hard drive, 16M cache, 7200 rpm, 3.0 gb/s (preformatted hd only)
1 tb data hard drive, 16M cache, 7200 rpm, 3.0 gb/s
24x dual format/double layer DVD+-R/+-RW + CDR/RW drive with lightscribe technology
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032&cm_re=24x_dual_layer_dvd%2b%2f-rw-_-27-118-032-_-Product
12-In-1 Internal Flash Media Card Reader/Writer
Thanks a lot for your help, I really appreciate it.
Jared
thermaltake v9 case
Jared
