Archived from groups: comp.sys.laptops (More info?)
Looks like my laptop is going to have to have a new power jack as
well. I just dropped it off at The Geek Squad at a nearby Best Buy
store. No estimate yet, but they said it will probably run $60-$120 to
get the old jack repaired or replaced. It will take a couple of weeks
to get it done.
For $300, sounds like they intend to replace the entire motherboard.
As I undestand it, this may be necessary if the jack is badly damaged,
but in most cases, the jack can be repaired.
Good luck,
-FGP
On Tue, 12 Oct 2004 05:28:00 GMT, "Dordogne"
<dordogne1@!<remove>!comcast.net> wrote:
>I need a replacement part for my Gateway Solo 9500. I need the Power
>Connector; the thing that you plug the AC adapter cable into.
>Gateway wants to charge 299.00 to fix it. I would like to soder it on
>myself. But, I can't find the damn thing, I don't see it in the case.
>Thanks in advance
