I'm building a new PC to upgrade from my Q6600 2.4gHz Quad. I am planning to use the following components, but I want to make sure they are compatible (size wise).
CPU: i7 930 (LGA 1366)
Cooler: Noctua NH-D14 (mostly worried about whether t
Mobo: Asus P6X58D-E
RAM: 6gb (3 * 2gb) DDR3 1600mHz Corsair XMS3 (compatible with cooler, I checked)
HDD: 1tb Caviar Black + 120gb Corsair Reactor Series SSD
Video: XFX Radeon 5870 1Gb * 2
PSU: 1200w Antec Quattro
Sound: Auzentech Forte Soundcard
Case: Cooler Master HAF 922 / Cooler Master Sniper Storm
I've checked spec-wise compatibility, but I haven't checked whether all of these will exactly fit. I know most of these will fit, but I'm mostly worried about using side-fans on the case and if it will come into contact with the Noctua NH-D14. My second issue is whether the Noctua NH-D14 will conflict with the Auzentech Forte soundcard (below the CPU socket). Also, which case should I get out of the CM Haf 922 or the CM Sniper Storm (both will be used with side fans).
Mobo: Asus P6X58D-E
