Best Power Supplies for 2x GTX 480 SLI
  • Power Supplies
  • Components
  • Product
Last response: in Components
August 2, 2010 8:42:55 PM
I was wondering what the best Power would be to easily support such a build. First, I should say that this is an entirely new build and that money is not a consideration. I also like my PSU's to be a bit overkill - I like a bit of headroom and don't want them anywhere near 100% usage.
My other question would be Modular or Single-Rail non-modular?
Components will be:
Case-------Cooler Master HAF X
Mobo-------Gigabyte GA-X58A-UD9
CPU---------Intel Core i7 980X Extreme
RAM---------Gskill PC12800 PI 12Gb DDR3 (6x2Gb) - F3-12800CL7T2-12GBPI (not sure yet)
Graphics---2x Gigabyte GeForce GTX480 1536MB GDDR5 with after-market air-cooling (GELID Solutions???). Possible use of a third card later on (new Fermi's coming in September-475/485????)
Other stuff:
- 2x Blue-Ray Recorders Plextor PX-B940SA Black
- 2x Western Digital RE4 2TB SATA 7200rpm 64MB
- An exhaust 3 fan radiator on top of the case, and a couple of other fans.
What PSU would you recommend for this stuff, and some other that I can't remember now?
More about : power supplies gtx 480 sli
August 2, 2010 8:55:18 PM
OOPPPPPPPPPSSSSSSS....
Almost forgot: 3X Monitors (30" +). Don't know what I can find yet, I would like them to be same make/model and S-IPS...
Suggestions would be appreciated, specially concerning availability.
August 2, 2010 9:10:26 PM
I just got Enermax Revolutions 1250w for a similar setup after reading lots of reviews.
a b ) Power supply
August 2, 2010 9:14:14 PM
corsair ax1200 but ideally silverstone strider 1500
August 3, 2010 5:04:38 AM
Modular or non-modular?
Does the Bronze, Silver and Gold rating mean anything, or do some companies just not care (like Silverstone)?
Thanks for the replies.
a c 296 ) Power supply
August 3, 2010 5:27:48 AM
the bronze, silver, and gold ratings are part of 80+, they tell you the efficiency range it falls into. More efficient units generate less heat so their fan can run less.
http://en.wikipedia.org/wiki/80_PLUS
I agree with Obsidian in that the AX1200 would be a great fit for a build of that level once it comes out, but since its not out yet the strider 1500 and antec TPQ-1200 are the only other high quality ones i know of that will have sufficient power to support 3 GTX 480s, a 980X, and a water cooling setup
a c 91 ) Power supply
August 3, 2010 12:24:16 PM
+1 for the Corsair AX 1200.. If you are somewhat skeptical on a full modular design, the Antec TPQ 1200 is worthy to consider..
August 3, 2010 7:30:48 PM
Thats going to be wayy more than you need, and since its a SUN PSU its likely not compatible with an ATX system. The E10K appears to be a large server tower so its probably a redundant power supply and therefore wont fit in the space of a standard PS/2 PSU.
August 6, 2010 6:17:23 AM
Thanks guys.
AX 1200 sounds like the best bet, unfortunately I would have to wait 2 or 3 weeks for them (in Portuguese time that would be about 2/3 months, or never...)
Managed to get my on an Antec TPQ 1200 (for only 155 Euros/$205USD) so I bought it.
Again, thanks so much for the feedback.
P.S. - Now to find those monitors...
