Hi, I recently put together a homebuilt system after reading the Tom's Hardware forums to learn about how to do it and what kind of components to use.
I have a problem now whenever I start it because instead of booting properly, all I get is a long continuous beep that doesn't stop and there is nothing that shows up on the screen. I think the problem may be with the video card, since I tried to remove it and successfully got the system to boot and could get into BIOS. Even when I have the video card in and it doesn't work, all the fans spin, including the video card fan. I will post what components I used. Please let me know if any of you have had a similar problem or if you have any ideas on how I could get it fixed.
https://secure.newegg.ca/WishList/MySavedWishDetail.aspx?ID=12829965
Here is the video card. I couldn't add it to the wish list because it's not available now.
Video Card: ASUS EAH5850 DirectCU TOP/2DIS/1GD5 Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ ATI Eyefinity
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121370&cm_re=asus_eah5850-_-14-121-370-_-Product
Thanks for taking the time to look at this.
