Cpu Motherboard Compatibility problem
Hello, I wanted to purchase a AMD 6 core CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103849&cm_re=amd_ii_x6-_-19-103-849-_-Product and didn't find a big variety of motherboards that supported it. There were a few but I was wondering if they were really worth that much. I mean 270 sounds a lot for a motherboard. At least thats my opinion. If you can find something for around 200 dollars that supports this cpu, that would be fantastic. Thanks! :D
7 answers Last reply
More about motherboard compatibility problem
  1. All AMD 890 boards will support that cpu.
    Most 880 boards will support it with a bios update.
    890GX boards will support onboard graphics with the cpu's igp.
    890FX boards have no onboard graphics and will require a discrete gpu.
    The selection is extensive on Newegg.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=amd+890+motherboard
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=amd+880+motherboard&x=15&y=35
  2. Thank you for the answer. I was wondering if you could tell me if the motherboard supported my build + the six core AMD processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157188&cm_re=amd_890_motherboard-_-13-157-188-_-Product
    Specs:
    Ati Radeon 5770 (I would like to crossfire x it and would like to have enough slots)
    PSU Rocketfish 500
    of course the AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz 6 CORE
    and I have a v9 black edition thermaltake case which keeps everything pretty cool XD
    Specs:
    PSU Rocketfish 500
    Absolutely the 890 boards were designed for the 6 core processors.
  4. Yes I understand but would a 500 W PSU be able to handle the CPU AND the components?
    That's a very good question!
    Something i was wondering myself as i know nothing about Rocketfish other then it's BestBuy/FutureShop inhouse.
    Theoretically a 500W is more then enough for 5770.Not to sure about yours though.
    A good quality 550-650W unit would easily handle 2x5770.
    Are you Canadian or American?
  6. American. Lets forget about crossfire. Lets zoom in on the motherboard and the PSU. My question is that if a 500 W PSU can handle powering the motherboard, fans (there are like 8 in my pc) in cluding the cpu fan, and the ati 5770.
  7. Why not go to the Corsair web site or some other PSU makers site and punch in the numbers on their self help guides. They will provide you with the power size you need. Frankly, if you ever think you might want a second GPU, I would size the PSU accordingly now rather than have to replace it next year or so. In other words, you want a minimum of 750 to 850 watts.
    PSU's are where a lot of folks go wrong. They go cheap and they regret it later. My advice is spend a bit more and get a gold rated PSU from one of the top tier PSU providers. That means Silverstone, Thermaltake, Corsair, Cooler Master, Antec and numerous others.
    A lot of people don't realize that PSU's lose there stuff every year you run them. I understand that 5-10% of the output is lost every year through general use and wear and tear. So an 850 watt unit today is a 765 or so watts in actual output next year. This is especially true when you buy a low price PSU with cheap components inside. Garbage in, garbage out.
    Hope this helps you. :)
Motherboards CPUs Compatibility Product
