What is the best PCI x16 that will work on Benicia-GL8E 400w power supply Q820
Motherboard description
Manufacturer's motherboard: Asus IPIBL-LB
HP/Compaq name: Benicia-GL8E
Form Factor
Micro-ATX: 24.5 cm (9.6 inches) x 24.5 cm (9.6 inches)
Chipset
Intel G33
Front-side bus speed
800/1066/1333 MHz
Processor upgrade information
Motherboard supports the following processor upgrades:
Intel Core 2 Quad (Y) Q9xxxx
Intel Core 2 Duo (W) E8xxx
Intel Core 2 Quad (K) up to Q6600
Core 2 Duo E6x00 (C) up to E6700
Core 2 Duo E4x00 (C) up to E4400
Memory upgrade information
Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supported DIMM types:
PC2-5300 (667 MHz)
PC2-6400 (800 MHz)
Non-ECC memory only, unbuffered
Supports 2GB DDR2 DIMMs
Supports up to 8 GB on 64 bit PCs
Supports up to 4 GB* on 32 bit PCs
*32-bit operating systems cannot address a full 4.0 GB of memory.
Video
Integrated graphics using Intel GMA 3100
*Integrated video is not available if a graphics card is installed
Also supports PCI Express x16 graphics cards*
Audio
Integrated Audio ALC888S
*Integrated audio is not available if a sound card is installed.
Audio CODEC: ALC888S
7.1 channel high-definition audio
Network
LAN: 10-Base-T
Interface: Integrated into motherboard
Technology: Realtek 8111C
Data transfer speeds: up to 10/100 Mb/s
Transmission standards:10-Base-T Ethernet
Expansion Slots
One PCI
One PCI Express x16
Two PCI Express x1
I/O Ports
Back I/O ports
Figure 2: Back I/O panel
1 - PS/2 mouse port (green)
2 - Coaxial SPDIF Out
3 - Video Graphics Adapter
4 - IEEE 1394a
5 - RJ45 Network (LAN)
6 - Auido: Center/Subwoofer (yellow orange)
7 - Auido: Rear Speaker Out (black)
8 - Audio: Line In (light blue)
9 - Audio: Line put (lime)
10 - Audio: Microphone (pink)
11 - Auido: Side Speaker Out (gray)
12 - USB 2.0 ports 1, 2, 3, and 4
13 - Coaxial SPDIF In
14 - PS/2 keyboard (purple)
Internal Connectors
One 24-pin ATX power connector
One 4-pin ATX power connector
Six SATA connectors
One floppy drive connector
Two 12v fan connectors for CPU fan and PC fan
One 9-pin header for power button, reset button, power LED, and HDD LED
Three USB 2.0 headers supporting 6 USB ports or devices
One IEEE 1394a header
One SPDIF audio output header
One 4-pin audio line-input connector (interrupts line input on back panel, Vista capable, requires matching front audio jack module)
One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack module)
1 answer Last reply
More about what work benicia gl8e 400w power supply q820
  1. I see you got a PS/2 mouse port, that is great mate.
    At school we, in our early ages, learn to ask questions by starting by hello and finishing by thanks.
    I bet you didn't go to school.
    Using 400 watts you won't go far if you want to play games.
    Also a bugdet would be nice.
    Otherwise I'd say grab a gtx 580 ?!?!
Motherboards
