Hello all,
I've been experiencing absolutely awful speeds out of my wireless card as of late. When hard wired, I get around 21Mbps from my Comcast connection, but when using wireless, I generally get < 3Mbps at any distance from the router.
Here's my card: http://www.newegg.com/Product/Product.aspx?Item=N82E16833124297
Yes, it's a pretty badly reviewed card, but most of the negative reviews are from people who couldn't get it to work whatsoever. It worked fine for me on Win7 32bit - just plug and play.
I know it's not the router that is at fault here, because a housemate of mine who uses an Apple laptop gets > 19Mbps via a wireless connection.
Is there anything I can do to remedy this situation? I'm really at a loss with anything dealing with networking. And if worse comes to worse and there is absolutely no solution, can you recommend a cheap, reliable wireless card that is capable of decent range?
Thanks for your time!
