New System Build ($2,000ish price point)
Would like to keep the final build at around $2,000. Willing to stretch a bit, up to $2,500 if absolutely necessary. Looking for suggestions. Chosen parts are also up for suggestions, but more than likely set in stone. All purpose computer, but with a focus on gaming and entertainment.
Current List of Chosen Parts - Current Total ($1,137.92)
CASE: COOLER MASTER COSMOS S RC-1100-KKN1-GP Black Aluminum ATX Full Tower Computer Case ($169.99)
PSU:
MOTHERBOARD:
CPU: Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor ($289.99)
RAM:
HARD DRIVE: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($69.99 x2 = $139.98)
OPITCAL DRIVES (i want two):
OPERATING SYSTEM: Microsoft Windows 7 Ultimate 64-bit 1-Pack for System Builders - OEM ($174.99)
KEYBOARD: Logitech G15 104 Normal Keys 29 Function Keys USB Wired Standard Gaming Keyboard ($79.99)
MOUSE: Logitech MX 518 8 Buttons 1 x Wheel USB Wired Optical 1800 dpi Gaming Mouse ($42.99)
MONITOR:
HEATSINK/CPU COOLER:
HEATSINK/CPU COOLER PASTE:
CASE REPLACEMENT FANS:
VIDEO CARD:
SPEAKERS/HEADPHONES:
5 answers Last reply
More about system build 000ish price point
  1. Goal here was to provide for a system capable of a 4.0 - 4.2 GHz Overclock w/ little effort and provide enough oomph for adding a 2nd card in SLI, w/ roomy case and top end PSU
    $150 Antec 1200 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
    $120 Antec CP-850 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371024
    Dang .... if not in a hurry, newegg usually has a combo on the two above for $220 - $240
    Alternate ($60 more) would be:
    $ 140 HAF 932 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
    $ 190 HX850 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
    $514 ASUS P6X58D-E w/ Intel i7-930 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.413933
    $155 3 x 2GB Corsair DDR3-1600 CAS 7 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145286
    (Add $65 if ya want the fastest http://www.newegg.com/Product/Product.aspx?Item=N82E16820226121)
    $80 Seagate Barracuda 7200.12 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
    Hard Drives - Check out the performance charts and pick whatever 500 GB per platter drive performs best under your usage patterns. The 2 TB WD Black and XT from Seagate are good choice but at smaller capacities, you are limited to the Seagate 7200.12 or the Spinpoint F3. The 7200.12 excels in gaming, multimedia and pictures whereas the F3 wins at music and movie maker. See the comparisons here (copy past link in manually, link won't work in forum):
    (http://www.tomshardware.com/charts/2009-3.5-desktop-hard-drive-charts/compare,1006.html?prod[2371]=on&prod[2770]=on)
    Look at the tests that reflect your usage and choose accordingly
    $101 Prolimatech Megahalems w/ twin PWM fans and IC Diamond TIM w/ PWM Cable splitter.
    Skip if not going to OC
    http://www.frozencpu.com/products/8807/cpu-pro-01/Prolimatech_Megahalems_Rev_B_Intel_CPU_Heatsink_LGA_775_1156_1366_AM2_AM2_AM3_Hot_Item.html
    http://www.frozencpu.com/products/7038/thr-41/Innovation_Cooling_Diamond_7_Carat_Thermal_Compound_-_15_Grams.html?id=BZWnrfIC
    http://www.frozencpu.com/products/10026/fan-639/Scythe_Slip_Stream_120mm_x_25mm_PWM_Fan_-_SY1225SL12LM-P.html?tl=g36c365s936
    http://www.frozencpu.com/products/8418/cab-150/FrozenCPU_PMW_Y_Splitter_Cable.html
    $43 Logitech MX-518 http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
    $60 Logitech G15 KB http://www.newegg.com/Product/Product.aspx?Item=N82E16823126034
    $175 Win7-64 Ultimate http://www.newegg.com/Product/Product.aspx?Item=N82E16832116762
    $275 ASUS VW266H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236047
    $50 Any DVD Writer x 2 Add $115 if you want one to be a Blue Ray Writer
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181
    $350 ASUS ENGTX470/2DI/1280MD5 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121372
    Hard to pick the choice here. If ya spend more money (+350), you could get a 5970 but twin 470's in SLI has better min. frame rates than the 5970 in DX11 games (1920 x 1200, hi settings) by about 23% (17% for avg. frame rates) .... could add the 2nd card come XMas time.
    Another option would be to get a 5850 and add a 2nd at Xmas....will save you $50 per card ($14%) but will also drop min. frame rates by about 19%. Each card is well priced for it's performance in the market so hard to find fault with any of those choices. This list below which provides the cost in "dollars per frame" (9 benches in DX11, 1920 x 1200 @ hi settings) might help ya choose.
    ATI 5850 8.89
    nVidia 470 9.08
    nVidi 480 10.01
    ATI 5870 10.08
    ATI 5970 11.51
    Total $2,173 for bolded items
  2. Is there a reason you need Windows 7 Ultimate?
  3. The Corsair 700 Obsidian is a REALLY nice case.
  4. Sony Optiarc DVD Burner with LightScribe Black SATA Model AD-7241S-0B LightScribe Support - OEM
    Item #: N82E16827118032
    Return Policy: Standard Return Policy
    Protect Your Investment (expand for options)
    Service Net Replacement Extended Warranty Plan
    The product will be replaced and shipped directly to you at no charge(more info)
    • 1 year: $6.99
    • 2 year: $11.99
    $21.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
    Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Item #: N82E16822148433
    • 1 year: $10.99
    • 2 year: $18.99
    $79.99
    ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
    Item #: N82E16824236049
    Return Policy: Monitor Standard Return Policy
    • 1 year: $25.99
    • 2 year: $45.99
    -$30.00 Instant
    $259.99
    $229.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
    XFX HD-587X-ZNFC Radeon HD 5870 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
    Item #: N82E16814150476
    Return Policy: VGA Replacement Only Return Policy
    $399.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150476
    Logitech G15 USB Wired Standard Gaming Keyboard
    Item #: N82E16823126034
    • 1 year: $9.99
    • 2 year: $16.99
    -$10.00 Instant
    $20.00 Mail-in Rebate
    $89.99
    $79.99
    Logitech G9x Black Two modes scroll USB Wired Laser Gaming Mouse
    Item #: N82E16826104261
    • 1 year: $9.99
    • 2 year: $16.99
    -$18.00 Instant
    $25.00 Mail-in Rebate
    $99.99
    $81.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16826104261
    G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL8TU-6GBPI
    Item #: N82E16820231247
    Return Policy: Memory Standard Return Policy
    $184.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
    Item #: N82E16832116754
    Return Policy: Software Standard Return Policy
    $99.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
    Noctua NF-P12-1300 120mm CPU Cooler and Case Fan
    Item #: N82E16835608004
    $25.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835608004
    Prolimatech Megahalems Rev.B CPU Cooler
    Item #: N82E16835242001
    -$7.99 Instant
    $69.99
    $62.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835242001
    SAMSUNG Black Blu-ray Combo Drive - Bulk SATA Model SH-B083L/BSBP LightScribe Support - OEM
    Item #: N82E16827151199
    • 1 year: $9.99
    • 2 year: $16.99
    $69.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151199
    Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD)
    Item #: N82E16820167023
    Return Policy: Limited Replacement Only Return Policy
    • 1 year: $25.99
    • 2 year: $45.99
    -$65.00 Instant
    $299.99
    $234.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023
    Creative Fatal1ty Gaming USB Headset - Smaller Box
    Item #: N82E16826158075
    • 1 year: $9.99
    • 2 year: $16.99
    $69.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16826158075
    • Corsair Obsidian Series 700D CC700D Black Aluminum / Steel ATX Full Tower Computer Case
    Item #: N82E16811139002
    • CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
    Item #: N82E16817139006
    -$80.00 Instant
    -$50.00 Combo
    $20.00 Mail-in Rebate Card
    $409.98
    $279.98
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.418869
    • Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor Model BX80601930
    Item #: N82E16819115225
    Return Policy: CPU Replacement Only Return Policy
    o 1 year: $29.99
    o 2 year: $59.99
    • ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    Item #: N82E16813131641
    o 1 year: $25.99
    o 2 year: $45.99
    -$5.00 Instant
    -$15.00 Combo
    $534.98
    $514.98
    Subtotal: $2,436.84
  5. BUMP!
New Build Systems Product
