I'm thinking about building a pc for around $1,200 max. I would like to go under this price but this would be max.
The monitor i was looking at was this http://www.newegg.com/Product/Product.aspx?Item=N82E16824009219.
OS- Windows 7 Home Premium (180 for new, 100 for OEM. Which should i get? Is it complicated to set it up?)
I need everything that you would need to use a computer. I was looking at the i7 but the Phenom II x4 looks sweet too. I'd use it for gaming, music, internet, so on.
This is just for part suggestions..if you want to you guys could do one core i7 and a Phenom II x4 build to compare.
Thanks
Thanks
