Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] Need Advice on Fan Speed Control
Forum Systems : New Build [Solved] Need Advice on Fan Speed Control
Best answer from banthracis.
I’m in the process of a build. The GA-P55A-UD3 has two 4 pin fan headers. One for CPU and the other for System fan 2. Any suggestions of a 200mm or 120mm 4pin system case fan with speed control?
System as follows:
Intel Core i5-750 (Lynnfield 4c) 2.66 GHz, DDR3-1333, 1 MB L2, 8 MB L3 Processor
http://www.newegg.com/Product/Prod [...] -_-Product
Gigabyte GA-P55A-UD3 (rev 1.0) Intel i5 i7 P55 1156 Motherboard
http://www.newegg.com/Product/Prod [...] %206gb%2fs
Antec Nine Hundred Mid -Tower ATX Computer Case
Antec EarthWatts 750w Continuous Power Supply
http://www.newegg.com/Product/Prod [...] tts%20750w
4GB DDR3 1600MHz Corsair CMX4GX3M2A1600C9 Memory (x 2)
http://www.newegg.com/Product/Prod [...] 3M2A1600C9
Fujitsu MAS3735N Ultra320 73.5GB SCSI HD 15000 RPM (x 3)
http://www.superwarehouse.com/Fuji [...] C/p/240698
Seagate ST1000340AS-RK SATA/ 300 1TB HD 7200 RPM (x 2)
http://www.frys.com/product/547827 [...] IN_RSLT_PG
Adaptec 39320A-R U320 SCSI RAID Card
http://www.adaptec.com/en-US/suppo [...] -39320A-R/
M-Audio Audiophile 2496 - 4-In/4-Out with MIDI and Digital I/O Audio Card
http://www.m-audio.com/products/en [...] e2496.html
Galaxy 24GGS8HX2PUX GeForce GT240 1GB SDDR3 PCI Express Video Card
http://www.frys.com/product/609249 [...] IN_RSLT_PG
Hauppauge WinTV-HVR-1600 ATSC/ClearQAM/NTSC TV Tuner PCI Card
ASUS DRW-24B1ST 24X DVDRW SATA
Plextor PX-760A DVD E-IDE (ATPI)
I’m not sure if the Gigabyte GA-P55A-UD3 is compatible with a PWM fan. Any ideas is appreciated.
Thanks.
Reply to wmjarvis88
Buy an Antec 1200, it has all the fans and each has its own speed control. Newegg has the 900 for $100 and the 1200 for $170. I don't know which will end up the better buy for you after you add the cost of any fans to the 900. If you go the 1200 you might use the CP-850 for the same price. Look at it for the 900 as well. With the 1200 all the fans except the cpu cooler run direct from the PS cabling so no connections or power load on the mb.
------------------------------ Antec1200,AntecCP850
AsusP6X58Premium
Inteli7920
CORSAIR XMS6G DR3 1600
Reply to DogSnake
Best answer
You could always just buy a separate fan controller. ~$30 for a good basic 4 fan controller.
Good cases with one built in include the Element G, and storm Sniper/Scout.
There's currently a great deal on the G, $90 after MIR
------------------------------ How to Ask For Build Advice
READ THIS before posting about boot/no video problems!
Reply to banthracis
Thanks for your reply DogShake,
The build was almost completed and I did not want to re-install in another case. I just went with the default setup with the 900. I am surprised by how quite the system runs. I will consider better case on next build. Thanks again.
Reply to wmjarvis88
Thanks for your reply banthracis,
The build was almost completed and I did look into some of the fan controllers.
I liked the AeroCool Touch 2000 Controller Panel : http://www.newegg.com/Product/Prod [...] 6811999198
which was also available at my local Fry's. However, I just went with the default setup with the 900. I am surprised by how quite the system runs.
I will consider better case or a fan controller on next build. Thanks again.
Reply to wmjarvis88
There are 1839 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 2 hours ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
