Opinions/thought New system build
Hi forum!
Im building my new system and i was wondering if anyone had any thought or advice on what i've come up with so far!:
Case: Antec Three Hundred Miditower
http://www.antec.com/Believe_it/product.php?id=MjQ=
+ 2x Cooler Master Case fan Neon L.E.D
Mobo: MSI P55 GD65
http://www.msi.com/index.php?func=proddesc&prod_no=1846&maincat_no=1
CPU: Intel core I7 860 quad @2.8GHz
http://ark.intel.com/Product.aspx?id=41316
+ CPU Cooler: Cooler Master CPU Hyper TX3
http://www.coolermaster-usa.com/product.php?category_id=1623&product_id=2922
RAM: 2X A-DATA DDR3 2GB 1333MHz PC3-10666, CL8
http://oc.adata.com.tw/1_product_detail.asp?pid=AD31333GU1K
HDD: Western Digital Caviar Black 540GB 7200rpm 32MB SATA2
http://www.wdc.com/en/products/products.asp?driveid=552
PSU: MAD-X PC MPS Magma 680 W (Dont know too much about it(their website is in french..))
http://www.mad-x.fr/products.php?id=129
GPU: 2 options depending on my paycheck this month:
1st:
MSI RADEON HD 5850 TWIN FROZR II - 1 GB GDDR5
http://eu.msi.com/index.php?func=proddesc&maincat_no=130&prod_no=2029
or: Sapphire Radeon HD 5770 XXX 1GB GDDR5
http://www.sapphiretech.com/presentation/product/?psn=0001&pid=290
Try to keep your replys on a constructive level! Thanks!
8 answers Last reply
More about opinions thought system build
  1. Hmm some info we need
    1. Where u getting your h/w ..possible to link to an online h/w site?
    2. Main use of rig and if gaming: what resolution
    3. Any current h/w that could be reused
    4. Max budget
    5. Try to hit an 80+ certified with active PFC PSU from Corsair, Antec, OCZ and if in Europe BeQuiet
  2. Linking the sites is hard since they would be in swedish + i'll be useing diffrent sites for almost every part...cheaper that way..
    Gaming at 1900x1200
    Current h/w is gaming laptop.. No luck im afraid!
    Mac budget in $ would be 1200 (or 1100 depending on that paycheck)
  3. Look to hit (in the GPU department) performance equalling or exceeding HD 5830
    The reason i choose the hd 5850 is http://www.videocardbenchmark.net/video_lookup.php?cpu=Radeon+HD+5850
    Everything ive read about it is positive...
  5. Yep just that your post stated Sapphire HD 5770 for consideration ^^ LGA 1156 also runs in dual channel so look for 2 x 2 DDR3 RAMs The $$ looks steep for me but if u can afford it ...
  6. Yes the 5770 is in case the money runs out.. Hopeing it wont..
    Thanks for the advice!
  7. You are welcomed ^^
New Build Systems
