I'm having a friend build the computer and they can't get it to POST. The following errors are what come up.
D1 - Perform keyboard controller BAT test. Check if waking up from power management suspend state. Save power-on CPUID value in scratch CMOS.
D3 - If memory sizing module not executed, start memory refresh and do memory sizing in Bootblock code. Do additional chipset intialization. Re-enable CACHE. Verify that flat mode is enabled.
C7 - Early CPU init Exit
Also, there is no video, but not sure if it's because of the above or another issue altogether.
What do they mean? How can I fix? Does this mean the Mobo is dead?
CPU: AMD 955 BE
GPU: XFX 5770
Cooler: Hyper 212+
RAM: GSkill Ripjaw that was on the mobo's qvl list.
CPU: AMD 955 BE
GPU: XFX 5770
Cooler: Hyper 212+
