[New System Build] Help New Build 900 <
APPROXIMATE PURCHASE DATE: Within next 2 weeks
BUDGET RANGE: Less than 900 Before Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Games, movies, music, surfing the Internet
PARTS NOT REQUIRED: keyboard, mouse, monitors, speakers, hdd, processor (Intel i7-930) , case (Antec p193)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, microcenter.com
COUNTRY OF ORIGIN: US
PARTS PREFERENCES: Asus mobo
OVERCLOCKING: Maybe
CROSSFIRE: Maybe
MONITOR RESOLUTIONS: 1680x1050 max
ADDITIONAL COMMENTS: I'm looking at getting the following, also looking to cut cost some. Unsure about memory selection.
2 - HIS Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card $116.99 each
CORSAIR CMPSU-850TX 850W Power Supply
$129.99
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$239.99
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit TR3X6G1600C9
$189.99
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
$25.99
Microsoft Windows 7 Home Premium Full
$179.99
8 answers Last reply
More about system build build
  1. Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
    Item #: N82E16827118030
    Return Policy: Standard Return Policy
    Protect Your Investment (expand for options27-118-030|hide options27-118-030)
    Service Net Replacement Extended Warranty Plan
    The product will be replaced and shipped directly to you at no charge(more info27-118-030.0.18)
    * 1 year: $6.99
    * 2 year: $11.99
    $19.99
    select item 2 quantity of item 2
    XFX HD-585X-ZNFV Radeon HD 5850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
    Item #: N82E16814150491
    Return Policy: VGA Replacement Only Return Policy
    -$20.00 Instant
    $309.99
    $289.99
    select item 3 quantity of item 3
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
    Item #: N82E16817139006
    -$30.00 Instant
    $20.00 Mail-in Rebate Card17-139-006
    $139.99
    $109.99
    select item 4 quantity of item 4
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
    Item #: N82E16832116754
    Return Policy: Software Standard Return Policy
    $99.99
    select item 5 quantity of item 5
    GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL9T-6GBNQ
    Item #: N82E16813128423
    Protect Your Investment (expand for options13-128-42310|hide options13-128-42310)
    The product will be replaced and shipped directly to you at no charge(more info13-128-4231.0.120)
    o 1 year: $25.99
    o 2 year: $45.99
    Item #: N82E16820231225
    Return Policy: Memory Standard Return Policy
    -$79.99 Combo
    $379.98
    $299.99
    Subtotal: $819.95
    Also if your going to overclock pick up a CM Hyper 212 off Amazon for 30$.
  2. Do you like it?
  3. Personally I would get the 5850 instead of two 4850s. Better power consumption, cooler, Direct X 11, very powerful and you can XFire in future. At a cost of about $50 (post rebate) more than 2 4850s it is well worth getting
  4. It's true but since hes on a budget it's going to be hard to put one in.
  5. I was hoping to stay with asus mobo. Totally stupid question here but how well with the 5850 deal with 2 monitor setup?
  6. Very well! The 5850 is a great card but two 4850s are still cheaper for the performance they offer.
    See: http://www.youtube.com/watch?v=OHi4F0WP4pA
  7. If my budget where a little higher what would you suggest?
  8. The 5850 it offers great performance but the 5770 is also great. Also if you want to Xfire two 5770s they will give about the same performance as the 5850 but if the game does not use Xfire it will run off one cad.. But did you think to go AMD and go with a 5870?
    Edit Sorry I forgot you had the i7 930 already.
New Build Systems
