I've been researching and checking prices on parts for a while now, and I think the parts that I've selected are a good price and will work well together, but this is my first build and I wanted to make sure I haven't messed something up. Mainly I'm looking for comments like "that ram won't work with your motherboard" or "that part isn't worth the price, get this instead". Just things that a first-time builder might overlook or not know about. Thanks for the help!
APPROXIMATE PURCHASE DATE: within a week
BUDGET RANGE: $1,000 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, browsing, movies
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com or Microcenter
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: The only parts I definitely don't want to change in the list below are the i7-930 and the 5850 (any part of that model is fine).
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: I'm planning on getting an SSD in a few months for an OS drive, so I just chose a big, decent hard drive for a storage drive.
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
Intel Core i7-930 Processor
http://www.microcenter.com/single_product_results.phtml?product_id=0331303
HIS H585FN1GD Radeon HD 5850 (Cypress Pro) 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161330
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Model F3-12800CL9T-6GBNQ
($80 less with a motherboard combo deal)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
OCZ ModXStream Pro OCZ700MXSP 700W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Antec Three Hundred ATX Mid Tower Case
http://www.microcenter.com/single_product_results.phtml?product_id=0283272
Sony Optiarc Black SATA DVD/CD Rewritable Drive
(free with a motherboard combo deal)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Western Digital Caviar Blue WD10EALS 1TB 7200 RPM SATA 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534
OVERCLOCKING: Yes
