What connectors do I need? And a *NEW PROBLEM*
Last response: in Components
I have a sound blaster audigy SE by creative, I need to connect something to it, but I don't know what. I already used up all my wires with my micro atx motherboard. I guess I will need to buy new ones, but I don't know which one. The connectors need to connect to here:
more info on specs:
http://www.provantage.com/creative-labs-30sb057000000~7...
More about : connectors problem
Googled it, found a review of the card, first guy reckons you dont need to plug it into anything, you should be fine as is it appears :)  the white one is for plugging in a cd drive apparently though
Moto
Moto
I tried downloading the driver for this card, but the driver detected no soundcard. I plugged the soundcard into the white slot here ( I have the same motherboard model as the picture, a micro atx dell 0m017g):
Related ressources
http://a.imageshack.us/img197/6156/showimgplcopy.gif
for some reason I can't edit, so here is the double post:
When I move my Lian LI PC-k58 computer, I hear buzzing noises from my speaker, why does it happen and how can I fix this?
I have the speakers plugged into my motherboard's integrated audio.
welshmousepk said:
Just cause there's an empty hole, don't mean ya have to fill it. or so the missus keeps telling me...
Can't agree with you more... Some catchy phrase there, by the way :lol:
Motopsychojdn said:
Is there anything in your bios to enable sound devices? mine has a 'front panel audio' tab, I deselect that, your Bios should, I say Should have similar
Moto
I only found my integrated audio in my bios utility set up. I can enable it and disable it, but I don't see my sound blaster audigy se.
Motopsychojdn said:
You wont,
disable your integrated audio, plug your sound card in and update drivers for it again, I'll check back in a bit, I need sleep Nightshifts :)
Moto
It didn't work.
BTW, my sound blaster audigy SE is from my old burnt computer, the card iteself even has some burnt marks on the metallic plate here:
So it could be that the card is broken, but I posted about this some time ago and replies said it should still work since there are no other burnt marks.
Vaylen said:
It didn't work.
http://img180.imageshack.us/img180/549/creativesoundblasteraud.jpg
Sorry, Vaylen is my abandoned account. Vay is my active account, but sometimes I forget while logging in and I auto fill the ID from the drop down list and log into my Vaylen account by accident.
Ask the community
