Here is my build:
MOTHERBOARD: ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365&cm_re=p6t_deluxe_v2-_-13-131-365-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
CPU: Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225&cm_re=930_i7-_-19-115-225-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
RAM: Mushkin Enhanced Blackline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 998781
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226102&cm_re=mushkin_6gb-_-20-226-102-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
GPU: XFX HD-587X-ZNDC Radeon HD 5870 (Cypress XT) XXX Edition 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150487&cm_re=xfx_5870-_-14-150-487-_-Product
HDD: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319&cm_re=wd_caviar_black-_-22-136-319-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
DVD: LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Writer LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335&cm_re=dvd_writer_24x-_-27-106-335-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
WIRELESS: ASUS PCE-N13 IEEE 802.11b/g/n PCI Express Wireless Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320048&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
So I need a case that can fit this mobo, with space for the PCI slots etc. It doesn't have to be pretty; the most important things are low cost, ease of use, and enough space to do future additions/upgrades.
Also: If I plan to do some slight overclocking and eventually add another GPU, which power supply do I need?
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply $125 AR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009&Tpk=corsair%20tx850
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=corsair%20750
