Are all of these parts compatible?
I am ordering these parts next week and I want to be sure if all of these parts are compatible with each other.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=18065507
The main thing that I am concern about is the CPU heatsink. Will it be able to fit in my case? Please note that I will not be buying these parts at newegg because of the taxes. Some items like the GPU is just there as a placeholder so that I can estimate my final cost. I am trying to get the XFX Radeon 5850 reference version and it seems like a lot of places are out. Tigerdirect seems to have it on their page, but it said estimate 7 to 14 days. Does anyone have any experience with back ordering the 5850 such as the length of your wait time? I might just back order it today just so that I can get it by the time the rest of my parts get here.
6 answers Last reply
More about parts compatible
  1. The heatsink will fit fine, but if you are concerned about space you can get a HAF 922 for less, it is almost 2 inches wider and has excellent airflow.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
    I would definitely swap the 750GB Caviar Black for the 1TB Samsung F3, its cheaper, larger and faster.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=F3%201tb
  2. All the components should work, although I'd get an ASUS P7P55D-E Pro motherboard instead of the GIGABYTE GA-P55A-UD4P. I'm not sure if the Cooler Master Hyper 212 Plus will fit into the NZXT Tempest EVO, although it should - the Tempest EVO seems pretty big, and the Cooler Master Hyper 212 Plus stands at 158mm tall.
  3. I have already bought my case awhile ago because it was $75 MIR and I also bought the Spinpoint F3 recently since it was $64 =). Sorry my wish list is not that updated, but that is about the only things that I have changed.
    I was also comparing the ASUS P7P55D-E Pro with the GIGABYTE GA-P55A-UD4P awhile ago, but I did not noticed much of a difference aside that the GIGABYTE GA-P55A-UD4P had more ports. How much better does the ASUS perform over the GIGABYTE? I am planning to OC my CPU. I might OC the GPU when the time is needed.
    EDITED: I just saw the Tempest Evo + the Hyper 212+ on someone's sig so I am assuming that they fit fine heh. I took some measurements and it seems like it barely fits and I was just trying to make sure.
  4. Hm.... I did a bit of research and it seems like the ASUS one is better if I am planning to use both SATA 3 and USB 3.0. I guess I'll go with that one then =)
  5. There seems to be an i7-875K on sale for $199.99 so I might pick that one up since it is the same price as my i5-750. Will the i7-875K work on my rig?
  6. The Asus P7P55D-E Pro supports the i7-875K as of bios 0806. http://www.asus.com/product.aspx?P_ID=T2FxW2fXGZQgSn2V
New Build Compatibility Systems Product
