Hello
I just bought a new system (X6 1055T + GA 880GM UD2H + Kingstone SSD V serie 64Gb + 2x2Gb DDR3 EDATA 1600G + Windows 7 x64))
I still have some errors (instability, freeze, etc..) This is my second set of ram. My 1st try was with 2x2Gb GSkill Ripjaws, and it was even worse
I though it was better with the new eDATA DDR3 (Newegg has good review)
I even re-installed Windows 7, and was able to encode 3 movies in a raw with handbrake without any crash or freeze
Bu this morning, when i started my computer, nothing on the screen. The indicator on the screen satyd ornage while it should turn blue
I did a reset 1 or 2 times, and then finally was able to start windows, but got a freeze few minutes after (f\glitches on the screen)
Then I decided to run a memtest (memtestv86 v4.10)
At around 45%, I've got 518,912 errors....!!!!
What's the issue?
Is it the RAM again, and I should try with a third set (!!!), or should I return my mobo+CPU and go for a i5-750 and another mobo for that CPU?
I'm completely lost..This is not my 1st built, but this is the first where I have so many issues!!!
I need some help please
What's the issue?
