Hello,
I recently replaced my dual 8800gtx's with a XFX 5870. However there is no display being shown on the monitor from boot. There is a signal being received (I think) as the no signal message is not displayed. Spec is as follows:
Motherboard: Striker II formula
Processor: E8500 with H50-1 cooler
Memory: 4Gb Corsair
Power supply : ST1000
I've tried different DVI cables, removing memory sticks, different PCI-E slots. Same problem. I RMA'd the card and they've returned it with a fairly comprehensive test sheet showing it's not faulty. Therefore, I concluded it must be a incompatibility with the motherboard and used it as a good excuse to upgrade. Therefore I bought:
Motherboard: Gigabyte X58A-UD3R
Processor: i7 920
Memory: Corsair XM3 6Gb
Inserting the XFX 5870 - same problem. PC boots fine but no output to screen. If I put my old 8800GTX back in, there's output to the screen straight away. Therefore the only conclusions I can come to is:
a) There is some sort of bizzare sync problem with the Samsung 225BW (have tried on both VGA and DVI).
b) The 5870 is actually faulty (although the PC is booting fine by the sounds of it)
I did plugging my PC into my Pansonic LCD TV and that gave the same results so it can't be the monitor??
Any advise would be greatly appreciated as it's driving me nuts.
Thanks in advance
Joel
Memory: 4Gb Corsair
Processor: i7 920
Thanks in advance
Joel
