Tom's Hardware > Forum > Digital Camera > Digital Camera General > [Help] Need Advice on Digital Camera for Hiker
Forum Digital Camera : Digital Camera General - [Help] Need Advice on Digital Camera for Hiker
Archived from groups: rec.photo.digital (More info?)
My father is a hiker who lives in Washington State. He's looking
for his first digital camera; currently considering a Kodak Easy
Share DX7590 because of the 10x optical zoom and relatively low
price. He's concerned, however, about moisture issues; if he packs
the camera in plastic bag(s), would there still be a problem with
condensation forming as the camera warms and/or cools (depending
on his elevation)? And if so, could it be severe enough to affect
the photos or the camera itself? No point in paying $500+ for a
camera system just to have it get ruined his first time out. Any
info/recommendations would be greatly appreciated, TIA...
J.J. in WA ~ mom, vid gamer, novice cook ~
"I rule you!" - Travis of the Cosmos, ATHF
Sponsored Links
Check out the Olympus Stylus Verve, 400, and 410. They're billed as
"all-weather"; I've heard they can be used in a rainstorm, although I
wouldn't actually submerse them.
Good Luck!
ECM
Reply to ECM
I'm no expert on anything with the moisture, but, I have a camera with a
10x optical zoom, and I find that the 10x zoom is more than I can handle.
Without a tripod anything zoomed in at that distance usually gets a bit
blurry. For that reason I usually don't use the full zoom.
consider getting a small hikers tripod too.
my guesses on the moisture..
moisture will not ruin the photo's, a friend of mine put his memory card
thru the washing machine, and it still works just fine.
I have used my camera on damp days and in the rain and have had no problems.
I keep it in a regular camera case and I have not had any trouble.
"Gal Called J.J." <jjsworldSPAM@BLOCKERzipcon.com> wrote in message
news:cpkp5k$e0k8_002@news.zipcon.net...
Reply to Anonymous
- 0 +
jjsworldSPAM@BLOCKERzipcon.com (Gal Called J.J.) wrote in news:cpkp5k
$e0k8_002@news.zipcon.net:
> if he packs
Assuming he's moving from the warm, moist environment to the cooler
place, putting the camera in a plastic bag at home will trap the moisture
inside the bag.
Better to allow the camera to aclimate than to trap it with it's
moisture, I would think.
Living in the southeast, we frequently have the other situation: moving
from cool & dry to hot & humid. Humidity will condense on the lens, but
it doesn't seem to harm the camera -- after it warms up the fog clears
and all is well.
Bob
Reply to Bob
>> if he packs
> moisture inside the bag.
> moving from cool & dry to hot & humid. Humidity will condense on the
> lens, but it doesn't seem to harm the camera -- after it warms up the
> fog clears and all is well.
> Bob
Condensation problems only become evident when subjecting the camera to
extreme temperature swings such as coming into a warm dwelling from an
outside winter enviroment. The changes found outside (hiking up and down
mountains) do not meet this condition. The camera only needs protection when
going from a very cold enviorment to a warm one - water *will* condense on
and in the cold camera. Sealing in a plastic bag while the camera comes up
to temp will do the trick.
No problem going from warm to cold.
Hope this helps.
Ken.
http://www.rupert.net/~solar
Return address supplied by 'spammotel'
http://www.spammotel.com
Reply to Anonymous
"JimmySchmittsLovesChocolateMilk" <nothing@doing.ca> writes:
Image stabalization as found on Panasonic FZ cameras, Konica Minolta
A1/A2/A200/Z3, the Canon S1, and Nikon 8800 can often times help reduce camera
shake that show up with long zoom lenses. Note, Image Stabalization does not
help reduce subject movement.
Michael Meissner
email: mrmnews@the-meissners.org
http://www.the-meissners.org
Reply to Anonymous
Just a short post to thank everyone who responded; I'll forward
your comments/suggestions to my Dad... :-)
One time on Usenet, jjsworldSPAM@BLOCKERzipcon.com (Gal Called J.J.)
Reply to Anonymous
There are 1107 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
