Phenom II x4 955 (stock hsf)
4GB PC5300 RAM
MSI 770-C45 AM2+
RADEON 4850 512MB (stock hsf)
80GB WD SATA
250 Seagate Barricuda SATA
CPU idle temp 25-31 celcius
GPU idle temp 35 celcius
(testing temps under load today and I will post results)
Looking for pointers on case cooling. Ive done some reading on negative pressure vs. positive pressure, fan position, etc. but I still feel ignorant on the subject. These pictures should pretty much sum up what im doing with my case, do you see anything unnecessary? A few of the fans are rigged in, erm, unorthodox ways. I plan to secure them better once I've finalized my cooling "concept". Ive also organized the wires better since I took these photos.
Disc drive bays are covered with a stretched out and perforated piece of sock (as I scrounge for a suitable replacement) for filtering, 2x 80mm fans behind it
Hard drive bay with 80mm fan pulling in through lower front case vent
Also, I have this empty PCI-e slot I would love to use, but standard slot fans are too wide and my north bridge is too tall. Anyone know of any skinny or adjustable snake-like slot fans?
Thanks in advance for any advice!
Tim
4GB PC5300 RAM
MSI 770-C45 AM2+
80GB WD SATA
Tim
