ATI Graphics problem
Hi guys, when playing games, I get a terrible draw distance (relates to textures in Cry sis, and shadows in The Sims 3), and shadows appear fuzzy/blurry, with pix-elated edges.
Strangely enough, this issue appeared a few months ago after performing a format and reinstall of Windows 7.
So far, I have tried:
- Swapping my GFX Card for other stock.
- Swapping my motherboard (at request of reseller).
- Clearing CMOS and updating BIOS (at request of ATI).
- Clearing all drivers and updating to latest drivers.
- Adjusting ATI Catalyst settings.
- Adjusting game settings.
- Ensuring that the computer hardware is installed properly.
And nothing has worked, or even improved the problem.
Thanks for the help in advance guys.
Images:
http://img641.imageshack.us/img641/5282/48259591.jpg
http://img186.imageshack.us/img186/9112/47361756.jpg
http://img683.imageshack.us/img683/1707/41763460.jpg
http://img24.imageshack.us/img24/6920/justcause22010042001425.png
Video:
http://www.youtube.com/watch?v=hxGpMO_v1WI
Hardware:
Video – HD5870
CPU – AMD Phenom II x3 720
Mobo – GA-MA790XT-UD4P
RAM – 4GB DDR3 1333 Kingston
9 answers Last reply
More about graphics problem
    Images:
    Video:
    Hardware:
    Video – HD5870
    hola hocho......we're all here bro....
    Okay 1st we ned 2 b sure that it's graph problem,try checking ur RAM,Remove oneslot and play with another ,Of course it'll run slowly but if texture are gud then the problem is in the removed RAM,try fitting removed RAM and taking out the fitted one if problem persists.If After this test both the RAM has same issue then it's confirmed graphic card issue.
    Now to solve it easily if done you re god,try refitting the graphics card and mathch the latest driver with ur current one......from ....
    http://ati.amd.com/support/driver.HTML
    gluck.......
    reply soon.......
  2. Hey mate, just tried that...and sadly it didn't work. I've already tried updating to the latest drivers too (catalyst 10.4).
  3. New photos, problem is getting worse. This was triggered by updating to Catalyst 10.4.
    http://img37.imageshack.us/img37/4179/sims32o.jpg
    http://img413.imageshack.us/img413/4893/sims3p.jpg
  4. Bro.....
    tis sems not a big isu but we surely tak car of t.did,utried clen install.Well just uninstall the drivers then delete every folder related to ATI graphics uninstall every thing .Now ur system is like new on with out any graphics driver and clean as a sugeons glove(atleast before the surgery) ,then install the drivers again and try refiting graphics card if not intgrated,give it a try.......
    dont hesitate to reply,everyone needs help.....and yes,is this happened due to overclocking,If yes then upper method will surely work if nothing work please reply before the situation worsen.
    hope u get out of problem instantly.......
    regars....
  5. Did you check your temperatures during gameplay?
  6. Yep, check temps. Also, what is your PSU?
  7. hey.......
    u have hardware grap accelerator....tryturning it donw ,There are issues like this in WIndows XP home.
    now try windows +R and type msconfig now wen you see a window go to startup tab diasble all and then go to the services and clik hide all microsoft services.Then turn off every other program which are useless except antivirus.
    RESTART>>>>>>
    now when u get up ull get message tat system utility has been change or like......Just okay is.Again go to msconfig and turn all all the start up>>>enable all.
    this is how a person in our forum solve,I dont know why this happened but it sounds ridiculous.....really......
    Okay move on...
  8. PSU is a 750w Antec Truepower, and I just got it swapped at the reseller...the problem has not changed at all.
    Also, I can't alter Hardware Acceleration, because my graphics card is not intergrated. ATI uses Catalyst.
    My temps are normal during gameplay.
    I'll try MSConfig now, but it shouldn't really change anything. But it's worth a shot. Post back soon.
  9. There was no difference...
Radeon ATI Graphics
