Sound driver help
Hey, I have a Computer and the Usb headset works for sound but Speakers do not work.
I have tried downloading the Sound driver from the Asus website
This is the motherboard here it here http://www.asus.com/product.aspx?P_ID=NFlvt10av3F7ayQ9
I downloaded the driver from that website but its telling me that i have the worng Os virson witch is Windows Xp Sp 3. i have also tried other websites but still no luck with it can anyone help?
1 answer Last reply
More about sound driver help
  1. Hi
    1)
    click Start, click Control Panel, double-click System, click the Hardware tab, and then click Device Manager. Is there a yellow exclamation mark next to the sound card/device? If there is update the drivers.
    2)
    USB headsets are soundcards, you have two soundcards in the PC, the headset and the soundcard. You need to make sure windows is using the right one for playback - go to Control panel and select 'Sounds and Audio Devices' click on the 'Audio' tab, check that the soundcard and not the USB headset is set as the default playback device.
    Stuart
Motherboards Sound Driver
