Phenom II X4 965/55 Motherboard help
hessieng
19
I decided am going to buy the Phenom II X4 965 or the 55 didnt decide yet
i need a motherboard ... with the ratio of price/performance
am willing to spend 70$ or less (preferred less :) -)
thanks alot
EDIT : Not going to overclock anything
am going to use ATI HD 5770 GPU
sparx_inc
25
Well specify your the exact use of your rig, if you are using for gaming you won't require much processing power, but if you multimedia applications that are CPU intensive, you will need a good proccy
hessieng
19
i will be using it for gaming but i dont want to upgrade again untill 2~3 years so am gonna get the quad core (incase in the future some games require 4 cores i would be in the safe side and wont be needing another upgrade)
sparx_inc
25
Yup there will be games optimized for multi threads and cores so get the quaddy
sparx_inc
25
Well 965 comes only in black edition with 3.4GHz stock speed other wise it doesn't have much difference with 945(3.0), 945BE(3.0),955BE(3.2)
We suggested 945 only because its non black edition to save your money as you won't overclock. You are free to choose any.
hessieng
19
what about the motherboard?
i need something without graphics card integrated ... and i want USB 3.0 if possible with Lan/Sound cards Integrated and supports the Phenom 965 (i am going with this cause i might OC when i learn more about it ) ... cheap one
i used to have a gigabyte one never ttried asus or anything else .. but i heard asus is cheaper and better? Please help? and a friend of mine suggested asrock or something like that
and could u please tell me the diference between the 965 140W and the 120W?
Now u want OC so, go with the 955 and safe few dollars because is the same that the 965 but with a drop multiplier to x16.
Now, if u want OC i suggest to u go with a good mobo Gigabyte, Asus or MSI the rest don't have my trust. ASRock is an ASUS company not with the same quality with with good prices.
The 140W use more power, is more difficult to OC, produces more heat and not all the mobos support that kind of CPUs.
A good mobo for ur need and the x4 955 is around $120.
