toshiba satellite 1905 charging problem
G
Guest
Guest
Archived from groups: comp.sys.laptops (More info?)
The laptop is a few years old with alot of miles on it. When i plug
the charger into the laptop the battery light will glow amber and
charge properly for a few minutes then the battery light will begin to
blink and the battery will discharge until the laptop shuts off. If i
pull the plug and plug it back in the laptop will begin to charge
properly again for a few minutes and then the light will begin
blinking again. I bought a new battery hoping this would solve the
problem, but the problem remains.
Please Help B4 my laptop goes flying out my window!
Andrew
2,439
sunofafish <bigcoupee@hotmail.com> wrote:
: The laptop is a few years old with alot of miles on it. When i plug
: the charger into the laptop the battery light will glow amber and
: charge properly for a few minutes then the battery light will begin to
: blink and the battery will discharge until the laptop shuts off. If i
: pull the plug and plug it back in the laptop will begin to charge
: properly again for a few minutes and then the light will begin
: blinking again. I bought a new battery hoping this would solve the
: problem, but the problem remains.
Sounds like the first battery was bad and perhaps the replacement is
too. Where did you get the new battery?
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
G
Guest
Guest
usenetMYSHOES@bizaveMYSHOES.com (Andrew) wrote in message news:<rkrhjzcasdc50484058009@bizaveMYSHOES.com>...
> Andrew
I really doubt that it is the battery, it is acting exactly the same
as with the old battery.
G
Guest
Guest
On 18 Oct 2004 13:40:25 -0700, bigcoupee@hotmail.com (sunofafish) wrote:
:>usenetMYSHOES@bizaveMYSHOES.com (Andrew) wrote in message news:<rkrhjzcasdc50484058009@bizaveMYSHOES.com>...
:>> sunofafish <bigcoupee@hotmail.com> wrote:
:>> : The laptop is a few years old with alot of miles on it. When i plug
:>> : the charger into the laptop the battery light will glow amber and
:>> : charge properly for a few minutes then the battery light will begin to
:>> : blink and the battery will discharge until the laptop shuts off. If i
:>> : pull the plug and plug it back in the laptop will begin to charge
:>> : properly again for a few minutes and then the light will begin
:>> : blinking again. I bought a new battery hoping this would solve the
:>> : problem, but the problem remains.
:>> Sounds like the first battery was bad and perhaps the replacement is
:>> too. Where did you get the new battery?
:>> Andrew
:>I really doubt that it is the battery, it is acting exactly the same
:>as with the old battery.
Well in that case there's only 2 other possibilities. Either a problem with
your AC adapter (cheap) or a problem with the charging circuitry on the
system board (expensive).
Good luck,
me/2
Andrew
2,439
: usenetMYSHOES@bizaveMYSHOES.com (Andrew) wrote in message news:<rkrhjzcasdc50484058009@bizaveMYSHOES.com>...
: > Sounds like the first battery was bad and perhaps the replacement is
: > too. Where did you get the new battery?
: I really doubt that it is the battery, it is acting exactly the same
: as with the old battery.
You think it's impossible to get a new battery that is bad? How long
do you think it had been sitting on a shelf?
Andrew
