Looking to build a new computer here as my old one is pretty much on its last legs. Won't be able to salvage much if anything from it beyond the monitor, so basically starting from scratch.
Mostly use my computer for gaming, but trying to stay on a budget.
How does this look? Would it all be compatible? Looking to spend around 500 dollars when all is said and done. Been a few years since I made my last computer so I'm a bit rusty to all the new stuff around.
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model AD2U800B1G5-DRH
Antec Basiq BP430 430W Continuous Power ATX12V Version 2.2 Active PFC Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.410793
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Antec VSK-2000 Black ATX Mid Tower Computer Case
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.395720
ASUS M4A785-M AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
AMD Athlon II X3 435 Rana 2.9GHz Socket AM3 95W Triple-Core Processor Model ADX435WFGIBOX
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.388284
SAPPHIRE 100253HDMI Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Low Profile Ready
Thank you for your time and help!
(edit. Whoops Urlllzz)
