Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > [Solved] Case Air Flow
Forum Systems : Homebuilt [Solved] Case Air Flow
Best answer from motopsychojdn.
Hey guys,
I recently built a new computer and I've been reading online that its best to have a negative pressure inside your case to have effective air flow. I have 5 fans total. Right now I have 2 120mm and 1 140mm as intakes and 1 120mm and 1 140mm as exhaust. My case is the Scout mid tower.
Would taking out one of my 120mm fans increase airflow and reduce temps?
Reply to g00se216
Best answer
Removing a fan will decrease airflow and possibly increase temperatures
if you want to play with pos/neg pressures, turn a fan round so an intake becomes an exhaust.
post more precise details on fans location, pc's living space clearances etc and I can have a think on it, Scouts are nice towers tho :P
Moto
------------------------------ Once you start watercooling, you are almost automatically inducted into the modding circles as well, because theres rarely a 'from the box, fits everyone' solution, its your ingenuity and resourcefulness that makes it all happen,
Reply to motopsychojdn
If you have a side fan take it out (it seems you have two). Leave just the front as intake and top and back as exhaust.
Reply to mosox
There are lots of opinions of whether positive or negative net internal pressure is best - I'm for positive, myself. But strictly from the standpoint of cooling, the key consideration is not net pressure, it is volume of air flowing through. Second-most important is smooth airflow path, especially past/through high heat producers. BUT, make sure the path does not simply bypass those heat producers and flow swiftly from intake to outlet without cooling anything.
Reply to Paperdoc
here is an general opinion .
side: intake
bottom:intake
front:intake.
rear: exhaust
top:exhaust.
i hav done this the top exhaust works as a chimney system this is the best option.
Reply to hamza_93
g00se216 wrote :
Hey guys,
Hey guys I really appreciate the responses. I moved a couple of the side panels fans around to have 1 intake and the other exhaust and it raised my temps 2C. Now I think I'm going to keep my fan setup this way: 2 side intakes, a rear exhaust, a top exhaust, and a front intake. So far my temps have been 5C cooler with this positive pressure and it gives me a somewhat of a woody. : )
Reply to g00se216
Thats the set up most would have recommended :) Glad you got sorted out man, only thing I'd add is, if you have several sidefans on a panel, have them all the same, intake or out,
Moto
Thank you for best answer dude :)
Moto
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1895 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 2 hours ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
