Just finished a build, plugged it in, power supply is receiving proper voltage but no response from any components.Checked 24 pin connector with a plug in power connector checker. The -5volt light failed to come on while the others lite up. Interestingly the fans worked with the checker plugged into the 24 pin connector and the 8 pin connected to the motherboard. Unplugged the 24 pin from checker, connected back to motherboard and once again no response from computer.
Any ideas---is 750 power supply not overdrawn.
