Solved
Front Panel Connectors
March 3, 2011 6:17:03 PM
So I bought a new case (NZXT M59) and it came with some connectors that I haven't used before. Have a foxconn/hp motherboard (uatx H-RS880) that came in my prebuilt. So can someone point me in the right direction and tell me where and what order to connect these cables.
Sorry for the bad pictures, I'm on my phone for the time being. Thanks in advance.
More about : front panel connectors
Best solution
March 3, 2011 7:03:47 PM
It wouldn't hurt even if you reverse the polarity. On your motherboard, there will be jumpers somewhere in the corner in a row for power LED, hard disk LED, restart switch, and power switch, and PC speaker.
If you have motherboard's manual, that's the place to look. Members here can't tell WHERE the jumpers are looking at these photographs because they are not visible here. Not the most efficient way.
a b V Motherboard
March 3, 2011 8:35:53 PM
It should say in the manual where to connect the front panel connectors
March 4, 2011 4:20:13 AM
Fixed, thanks.
March 4, 2011 4:20:23 AM
Best answer selected by ivanlbc562.
August 23, 2011 7:58:26 PM
Ivan, did you get them all plugged in properly? I have the same mobo and have not plugged them all in.
SORRY FOR THE NECRO. Lol, I didn't want to start an entirely new thread for this issue.
