Will a cm 690 advanced II fit a with frio cooler
  • Power Supplies
  • Cooling
  • Components
  • Product
Last response: in Components
August 9, 2010 5:22:28 AM
Will it fit ?
More about : 690 advanced fit frio cooler
a b ) Power supply
August 9, 2010 4:20:38 PM
Found the following review on Newegg. Says it will fit, but will be tight. Good luck!
Pros: Keeps my components cool. Didn't do a test stock vs frio, but this thing works great at keeping my overclocked CPU in the high 30s at idle. 66°C at full load using prime95 stress test. Not too bad considering I'm 1Ghz over my stock clock (3.88Ghz). on a stock set up I was at 29°-31°C Idle/59°C Load.
Cons: HUGE. Make sure you have a big enough case, mine barely fit in the Cooler Master 690 (about 5mm to spare).
Item link at: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
August 10, 2010 3:52:37 AM
thanks for digging this up! I might just go with it.
m
l
