Closed
Audio/Volume icon in the task bar not showing
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
The volume icon is not showing in the task bar icons areas. I have verified
the following:
1. The icon is not configured to be hidden
2. The check box of showing the volume icon in the control panel ==> Audio
settings is checked- It is working manually but when I start up the computer
the icon is missing again.
Any suggestions how to fix it?
Thanks,
  • Saga Lout has closed this thread
Hello Mickey
Go here
http://www.kellys-korner-xp.com/xp_abc.htm
Click V scroll to Volume Control
Good Day
River Rat
"Mickey" <Mickey@discussions.microsoft.com> wrote in message
news:5FDB011A-298C-4D9E-B08A-ACB235A9153C@microsoft.com...
the following:
Thanks,
1-Right Click on task bar.
2-Click on properties.
3-find notification are there u'll find Customize tab..Just Click on it.
4-Now a Pop-up window will Appear..On the Bottom left corner u'll get an Option "Turn System icons on or off"
5-Just Click on it.then a window will appear then in icon behavior u can turn on or off..Just in Volume icon select on from dropdownlist.then ur Volume icon will be back in the taskbar :)
u can apply this setting if u want to recover ur other icons in the taskbar like..Clock, Network, power.
Thanks
Regards
Er.Aditya Rajput.
