i have a signifficantly old computer ATX that functions as it should but when i converted the psu using these instructions:
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
it doesnt turn on it sort of vibrates slightly for 0.5 seconds and stops.
heres what i have done so far i have connected the green to the black and connected the brown to the orange and loaded the device and powered it on but it doesnt work and when i had it in my computer it worked fine.
i have loaded it with: 1 or 2 light bulbs rated 12V result: failed to start.
a hard drive result: failed to start.
a hard drive and two disk rewriters result: failed to start.
all the drives and light bulbs work as intended so there MUST be something i did wrong.
i have also noticed there isnt a grey wire on this ATX whitch i find a bit strange.
i dont understand why the thing doesnt work because the last one i made was amazing it worked first time!
