Come ON! FAN Speed!
Fetal
760
Guys, i am quite fed up. even though i said i don't care about noise...
After closing my casing, the Excalibur i installed in front makes much more noise and much deepen one. I have connected it to motherboard chassis fan. Now speed fan cant control it, that's extreme crap. My mobo is p5kpl-AM SE.
speed fan detects it but cant change speed. Its running at 2200rpm constant :sweat: . temps are reall good, but noise suks. i should be able to control it. Can anyone mail the guy who made it to fix this. Come on guys help.
P.S. don't suggest hardware controlling, don't spam please.
Fetal
760
P5kpl mobos support q-fan system for cpu fan only.
in bios i can see the rpm only. that's it.
.. or may be its me that cant control the speed. any specific fiddling with settings?
Fetal
760
nah man. i have Cooler Master Excalibur 120mm beast. Connected directly to mobo chs port.
disabling any control in bios for cpu fan= that you can control it from speed fan but that too not much, bios can rev it much higher.
Excalibur is same. 2200rpm constant what so ever.
Fetal
760
well then why shouldn't i just open the side covering? the sound quietens a bit. Those aren't solution(s).
Any other software? or someone as i said specific fiddling around? cuz i know if i disconnect it, the hdd's temps and mb temps rise up more than 10degrees.
(shows how happy i am with cooling, and its eats the competitors alive. Gentle typhoon this and that. even r4's in alot of tests. OWNAGE /_\)
Timop
A resister would work, but the more realistic way is getting a fan controller.
Is the fan connected via molex or a 3-pin on the mobo?
Fetal
760
3 pin.
+ why does this fan have 4 point face? PWM is outa my jurisdiction, i don't understand it fully :p.
Only CPU fan connector on mobo has 4pin female for 4pin male (like of Excalibur) to be connected. may be there is some advantage over 3pin? or not?
Fetal
760
Any progress? i need soluUUtions. not $olution$.
Any chance it gets fixed in new Speedfan version? (is speedfan Dev on this forum :D)
Any other software? I cant get hardware cuz its not available in my country. I am really happy to spend under 25buks to get a controller. But its not available here. Thats why i said not to tell Hardware solutions.
