Hey guys, thanks for reading and helping out.
This is my first build, so I hope I explain everything correctly. I have included pictures. As soon as this fan issue is resolved I'm ready to power-up my first build!
MOBO: Gigabyte 890GPA-UD3H
PSU: Antec Truepower 750W
Fans: x4
I'm confused with the fan wiring. I know the fan power molex plugs snap in to the power supply cable, but the small connector on the end doesn't look like it fits in the SYS_FAN1 connector. I don't see any other 4 pin plugs on the mobo for fans, every other fan plug is 3 pins.
This is the end connector, I think it goes in the SYS_FAN1 slot.
These are the molex connectors the fans plug in to for power.
This is the SYS_FAN1 on the mobo.
Fans: x4
