Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Final build checkover + case + CPU cooler
Forum Systems : New Build Final build checkover + case + CPU cooler
Hello everybody. This is my new gaming build. Could any of y'all check stuff over for compatibility just in case?
Newegg public wishlist:
http://secure.newegg.com/WishList/ [...] r=18106927
Also, any other case recommendations/recommendations for a different CPU cooler? I plan on OCing.
Thanks everybody! Hoping to order tonight!
Reply to rockgardenlove
Only change I would recommend is getting the Cooler Master HAF 922 instead. It is a better case for similar price.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Thanks for the recommendation.
Any less flashy cases y'all could recommend?
Or with blue lights at least? :D
And is this cooler excessive for my overclocking purposes? I plan to push the i5 750 as far as I can at good temps.
Also, any other stuff I need for my first build?
I picked up some Arctic Silver 5 for heatsinking. Anything else I'll need?
Message edited by rockgardenlove on 06-09-2010 at 06:38:19 AM
Quote :
less flashy.. but blue lights?
Cooler Master 690 II, Antec 900/902 are a bit less flashy (the 900/902 have lights but you can't turn them off easily, CM II you can turn then off I think)
------------------------------ More pics of my rabbits :)
It doesn't seem logical: $200 on a monitor and $200 on a graphics card. $0 on a sound card and $50 on speakers.
Reply to Mark Heath
I have a CM II and you can turn off the front intake fan light.
I also have an Antec 902 and you can only turn off the bigboy top exhaust fan light.
A cheaper hsf alternative that will work and same quality just not as huge
http://www.newegg.com/Product/Prod [...] 6835608014
Reply to davcon
Fantastic Cooler for the price, its meant to be called the Mugen, i had one before i upgraded to the Scythe Yasya, really nice, if slightly larger than others
Reply to Hereisphilly
Nice!
This is pretty much the Intel version of my build with a better video card, better cooler and minus a SSD.
I'd love to post comparing benchmarks!
Reply to TTMC
There are 1890 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 2 hours ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
