Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Cabinet with built-in SMPS (450 Watts)
Forum CPU & Components : Power Supplies, Cases & Mods Cabinet with built-in SMPS (450 Watts)
Hello guys, this is my first post here on tom's.
I was about to buy GTX 460 and would like some help from you all.
Here are my specs:
Processor : Intel Core 2 Duo E4600 (2.4 GHz)
Mother Board : Mercury PNMCP73V (Nvidia GeForce7050/610i chipset)
Hard Disks : ST31000340AS Barracuda 7200.11 SATA 3Gb/s 1-TB
: ST3500410AS Barracuda 7200.12 SATA 3Gb/s 500GB
: ST3250410AS Barracuda 7200.10 SATA 3.0Gb/s 250-GB
PCI Slots : PCI E x 16 (I dont know whether PCI-E 2.0 or not!)
DVD Writer : Dual Layer LG DVD Writer (It doesn't matter i think)
RAM : DDR2 Ram - 2GB (However it shows only 1.76 GB)
And here comes the main problem. I have Frontech Cabinet with an inbuilt SMPS which shows it is 450 Watts. (Model: JIL-2410D)
Can i run GTX 460 with this cabinet with inbuilt smps?
Is SMPS & PSU both same? (sorry for being so noob here :D)
When i went to buy it in a retail shop, the guy at the shop said that graphics card cannot
be run on SMPS and they will burn if did so. Is it true?
I have got this information on smps:
info on smps
original pics:
original pic1
original pic2
original pic3
thanks for help in advance.
EDIT:
I was wondering if i could use a separate psu for Graphic cards. What i mean is, i would use my inbuilt SMPS for all other components like- motherboard, CPU, Hard disks etc. and would buy a 300W or more capable PSU only for GTX 460. Is it possible?
Message edited by vinay016 on 08-10-2010 at 09:26:44 AM
Reply to vinay016
Getting 404's on your links man, but I reckon your easiest option is factor in a new case and psu as well
and no, your pcie slot doesn't support pcie2.0 Sorry
Moto
------------------------------ Once you start watercooling, you are almost automatically inducted into the modding circles as well, because theres rarely a 'from the box, fits everyone' solution, its your ingenuity and resourcefulness that makes it all happen,
Reply to motopsychojdn
Moto
yeah sorry brother :o . fixed the images now.
Reply to vinay016
Both the case and the PSU need to be changed.. Otherwise you might end up permanently keeping the side door of that frontech open thinking about better airflow.. I'd seriouslly recommend you to spend up a little here as a quality case and PSU will serve for a long time..
Reply to Emperus
Frontech PSU and GTX 460? You must be dreaming. Either dump the idea of getting the GPU or dump the PSU int he garbage bin. If you use the PSU with the GPU, then you may end up dumping the PC!
Quite poetic isn't it?? :D
Get a Corsair VX550W - 5.5k INR.
CM690 - 4.5k-5k INR.
I am sticking my neck out and saying you are from India! :)
PSU and SMPS are the same thing.
Reply to hell_storm2004
OK fine well said. I am from india :p
And how about the other idea i put on in the first post as "Edit":
The guy at the shop said there is a gigabyte 450 w for Rs. 2300 approximately.
now im thinking if i get any PSU of around 300 W which would cost less than Rs. 2000, and use it only for graphic card(not whole system). :p
It would mean that i will be using 2 SMPSes
Message edited by vinay016 on 08-10-2010 at 10:19:03 AM
Reply to vinay016
I read somewhere that 2 PSU's can be used.
But 2 crap PSU's are as good as one crap PSU's.
I checked the power consumptions of the GTX460 1GB, i said around 270W on load. Then i guess you maybe better off with VX450W, although i must say, its quite a tight fit. I would definitely rate VX550W or Seasonic 500W.
http://techshop.in/store/product_i [...] ts_id=3569
or
http://www.lynx-india.com/index.php?productID=5137
Since the Corsair one is 4.5k then i suggest there should be no problem going for it.
GTX 460 is almost in the high end cards domain.. You may as well show some respect for your purchase by getting a proper (single) PSU.. Moreover, low end PSU's do not output their advertised watts also.. Then there are problems with efficiency, ripples, current etc..etc.. You will end up requiring a major fix if you go about trusting such PSU's.. hell_storm has put together a good combo recommendation.. Get the PSU atleast if you cannot afford the case for now..
Reply to Emperus
Agree with Emperus here, cheap PSU's maybe rated at 500W but they don't give the output of 500W when on load or when needed. On top of that most of them don't have active PFC. Which can be a bummer and unclean power is something that cheap PSU's expertise in. High ripple, high fluctuations and the works.
Modern day PC parts cant handle all these. They have to much of stress thinking about how to handle Crysis or Arma II. :)
Is Gigabyte 450 W good one?
Reply to vinay016
Its is good. But not enough for GTX460. You need a little more room than 450W for a GTX460
hell_storm2004, thanks for the help man (all the way in this topic). :love:
But i need to know one thing.
I have read about multiple psu's
http://www.overclock.net/faqs/1575 [...] power.html
why such mod using jumpers etc., i dont understand. is it necessary.
in my case, i will continue my usual computing through the inbuilt smps which takes input from one slot (cable1) in my ups, and for gaming i would buy gigabyte psu, which would take input from the spike (drawn from ups)(cable2). i will place my new psu on top of my pc or on my computer table, i have no problem doing this.
so new entire 450 w for a graphic card itself. How does this sounds ?? It means i will be using only the 6pin connectors from the new psu for my graphic card.
Power bill will hit me though.
Reply to vinay016
I know that people have used 2 PSU's in one PC. But i am not that type. I would definitely prefer one hefty solution rather than the bits and pieces of it and Corsair, Seasonic, Antec provide such solutions. That's why i said about the two PSU's linked above. The Corsair PSU's are the ultimate choice in quality, popularity and build and of course reliability. You need to buy one to understand what PSU quality means. Starting from the packaging to the cables and the rest. I was simply amazed when i opened my VX450W (Even i have been a Frontech PSU guy way back in the early 2002-2003 but with time have realized the importance of a good PSU. :)
Actually i have to say this to u earlier, but sorry for adding this. My budget is around Rs.2 to 2.5k for PSU. Since i've already paid money in advance for my GTX 460 768 MB. (i thought of buying 1GB, but later got to know that my PSU is *** and dropped to 768 mb version.)
Message edited by vinay016 on 08-10-2010 at 02:00:07 PM
Reply to vinay016
I guess nothing can be done now. Remember, PSU comes first. Decide on what you are going to get, how much wattage you need and get the PSU first. Rest all parts can wait for either you saving money or getting cash from somewhere unexpected, whichever comes first! :)
@hell_storm, thanks for this.
However, i am thinking about this thread:
http://www.tomshardware.com/forum/ [...] cated-help
and wondering if i could get something like this in India.:
http://www.tigerdirect.com/applica [...] M9b7DqXQtg
Reply to vinay016
Sorry... dedicated PSU's are not available in India as far as i know. Check some shops around maybe you can find some.
OK thanks for the help so far. I will update you with my luck.
meanwhile, i got this also from net (looks pretty good with 250 W):
http://www.hardwarehounds.com/tech [...] ress.shtml
Message edited by vinay016 on 08-10-2010 at 02:09:46 PM
Reply to vinay016
I know the Fortron PSUs, the 500 is 2x12VX18A.
Reply to mosox
Looks good, what is the Active Power Factor, and efficiency in ur opinion.
Also i may look in stores nearby for this. Thanks anyway.
Reply to vinay016
You should not be bothered about Active PFC and efficiency.. Like i said before, they would be there for advertisement and will happily fail to achieve those marks when made to go through a rigorous test.. Consider it like the DCR mentioned on the LCD monitors.. I'd still recommend you to get to the market and ask around for PSU's available in your price bracket.. For the budget you mentioned, i guess You'll surely get something from the coolermaster camp which would be far better comparing to such brands as frontech..
Reply to Emperus
OK i will look for coolermaster as well. thanks for adding.
Reply to vinay016
Finally you found something much more respectful.. Good going.. Either of those two will do..
Reply to Emperus
Fortron is better than Cooler Master.
And they just reduced the price on the 500W, now it costs just as much as the 400W version or it's an error?
http://www.theitdepot.com/details- [...] P6358.html
Reply to mosox
fsp sucks dood. cm is better...and not as overpriced
Reply to shovenose
Guys, sorry but i bought gigabyte 460 watts psu at last.
There was cooler master available with him, but he said it has no APFC and said it is not as better as gigabyte 460 watts.
This psu has got +12v1@14A and +12v2@15A.
I think it is more than enough right?
I bought this PSU with Galaxy GTX460 768mb.(No other shops did have stock of this card.)
I have tested this card till 3:00AM (IST) here.
So far So good.
I will update u guys when my psu goes boom. :pt1cable: (Just Kidding!!)
And i think there will be no more upgrade for 3-4 months in future.
In future i'm hoping to buy a good 1000W psu.:)
Message edited by vinay016 on 08-12-2010 at 06:35:21 AM
Reply to vinay016
If you are not going to use two, big, powerful, expensive video cards, you do not need a 1 kw PSU. Something like a Corsair 550VX will power a system with any CPU and any video card with a single GPU.
Reply to jsc
Hey i got this doubt. My Galaxy GTX 460 is Galaxy clocked (GC). They have another model - Galaxy GTX 460 Super Clocked (SC). Mine is overclocked to 700 MHz (core speed) and SC version is overclocked to about 800+ MHz (core speed). Can i achieve this 800+ with my GC Version? Iam just asking this and not going to do this however. I just wanted to know whether i saved some bucks not buying SC Version. Thank you.
My Graphic card's info:
http://a.imageshack.us/img821/5165/460768mb.gif
@jsc
i want to actually upgrade to something like this in future:
http://a.imageshack.us/img188/2722/b15w.jpg
Message edited by vinay016 on 08-12-2010 at 11:46:24 AM
Reply to vinay016
hi, can i run an ATI 512mb 5670 graphics card, and two HDD ( 1tb + 500gb) with an smps of 450W?? or should i upgrade my smps.
Reply to Anonymous
cndu, please start a new thread.
but yes a good quality 450w psu could easily handle that.
Reply to shovenose
my sys config
4gb ram ddr2
2tb hard disk
quad core processor
9500gt 1gb
guys im going to buy msi gtx 460 1gb .Is my mercury 450 watts psu is enough for that?
Message edited by aravinddec28 on 12-09-2010 at 03:17:59 PM
Reply to aravinddec28
no that is not a good psu. go for a good quality (thus expensive) 450w psu, from a brand like antec, seasonic , corsair, etc
Reply to shovenose
There are 1902 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 9 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
