Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Why did the wires from my power supply to the motherboard melt
Forum Systems : New Build Why did the wires from my power supply to the motherboard melt
Hello,
i recently built a computer everything new except my hdd. in the specs for the mobo it says it needs a min. of 450w i have a 530w. the power supply has an led light also. at first when i tried to start the computer the fans and lights lit up for maybe a second thats with both atx connected. the 12 pin and the 4 pin. then i took the 4 pin out and it started up but wouldn't boot up. and there is a red switch on the back of the power supply that i think changes the output. because i can get the compter to turn on but the wires to the 4 pinstart smoking and i already melted some. then used electrical tape and taped them up. is the reason my wires are melting because i still don't have enough power?
Reply to Rayn88
Your mobo may need 450w, but your HDD needs some, and your CPU needs some, and your fans need their share.
The red switch on the back... It says 110 and 220. A standard outlet is 110, if you put it on 220 i'm not sure what would happen. Nothing good though.
My advise, dont build something unless you know what you're doing.
Reply to magruder13
Its actually 24-pins and 8-pins connectors. The 24-pins connector supplies power to the motherboard, and the 8-pins connector supplies power to the CPU.
If you have a red switch at the back of the PSU, it is for selecting 220/110 Volts input. Whatever you did, if the wires (insulation) on the 8-pins connector melted, it means that there is a short-circuit somewhere that caused it.
DO NOT re-connect anything until the source of the short-circuit is determined and corrected.
Message edited by Ubrales on 06-09-2010 at 05:10:37 PM
Reply to Ubrales
I had feeling that it had to do with the power so i went ahead and got a 630w hoping that will be enough. it comes in today. but i still have the fear that it may not be the problem. I still don't understand why the 12 pin is fine but the 4 pin or cpu power over heated and melted I've been looking for the specs. i think it's 600w so does that mean that the 630w still wont be enough?
Reply to Rayn88
do i look for the short on the mobo or the psu
Reply to Rayn88
Lesson from experience. Don't cheap on power supplies. Hopefully you didn't fry anything.
Reply to ohiou_grad_06
I hope your new PSU doesnt have the red switch on it too. That is a sign of an older or crappier design.
Check your motherboard for bulged or burst capacitors, the extra power that melted your 4 pin connector likely damaged other components on your motherboard.
Reply to hunter315
You should also list your full build so we have an idea of exactly how much power it would need.
------------------------------ How to Ask For Build Advice
READ THIS before posting about boot/no video problems!
Reply to banthracis
Was your old psu a raidmax?
Reply to Idlewild
there are no bulges or scortch marks
Reply to Rayn88
my mobo is an extrme design M4A88TD-V Evo/usb3 i'll try to get links i'm a lil pressed for time right now. i have a PNY Verto GeForce 210 graphics card. CPU is AMD Phenom II X4 955 X4. 2X 2GB ADATA DDR3 1333 for RAM. 3 diff. Fans
Reply to Rayn88
thank you guys for your input it helped out i figured out the problem only to run into another one. my mobo wont recognize my hard drive. am i wrong to think that all i should have to do is have everything plugged in correctly and start up properly so it will boot up to windows? the OS should be on the hdd right? i shouldn't have to try and install my OS with the disk like i am in order to try to get my hdd to be recognized should i?
Reply to Rayn88
You ALWAYS want to reinstall your OS on a new build unless you have no other choice. There are so many differences with drivers and what not, it's best to reinstall.
Make sure the HDD is in the Sata port, make sure the HDD is connected to the power supply.
If it is an old HDD from another computer then the fact it has an OS on it is irrelevant, you need to reinstall an OS else it will not boot.
You need to put the OS disk in your DVD drive, you need to go into the Bios and change boot order to DVD drive as first boot device and then go through installing the OS
Reply to asteldian
i have done that and vista which i have says there is no hdd in any SATA port and i assure you it is there. i just got realised in my manual it says that NTFS is not supported in DOS invironment could that be why it won't recognise it should i convert it to FAT32?
Reply to Rayn88
Does your board recognize the drive? Also check in the bios, sometimes I think SATA drives like to run in IDE mode.
no bios doesn't either and i've tried IDE and AHCI
Reply to Rayn88
Hopefully you didn't burn something....I know with one build I did, I cheaped on the power supply, took the motherboard out. Started not reading IDE ports, and there you had it. Could try another sata port, and a new cable to be safe. But it's possible you fried something on the board, or the hard drive itself.
I don't think so your board is fairly current so there's no way it can't recognize a ntfs boot partition. Either you're doing something wrong or you're doing something wrong.
Set oyur sata drives to AHCI mode. And just boot with the HD and dvd drive, no extra ide drives if you had those connected. But as suggested I'm thinking you fried something as well.
Reply to fastx21
yeah i went to justanswer.com and talked to another expert he didn't say i fried anything but he did say that i probably got a mobo that had SATA problems that didn't allow it to recognize hdd so i'm going to try to exchange it and i know that my hard drives are ok because i booted using both of them on my old computer which i'm on right now. i just don't understand why it will recognize my cd rom drive but not my hdd. amd it has to be the ports also because i go to install vista and it doesn't find it either.
Reply to Rayn88
Like I said, I know I cheaped on the power supply, and I think it was a few days later that ports on my board totally died. Exchanged the board, all was well. But just thinking that with wires melting=not good.
Raidmax has notoriously terrible PSUs, their PSUs deliver two/thirds its rated wattage, poor voltage stability and ripple suppression, and full of cheap caps that will fail very fast.
Go for Antec, Seasonic, or Corsair.
Reply to Idlewild
There are 1904 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 2 hours ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
