I will try to be as thorough as possible. First, my system:
AMD Phenom II X4 965 BE (CnQ is confirmed working)
Gigabyte GA-790XTA-UD4
4GB (2x2GB) A-DATA 1600 MHz DDR3 1.55-1.65V
ASUS Radeon 5770 CuCore
500GB Western Digital Caviar Green
IDE DVD + IDE DVDRW
Antec Basiq 550 Plus
Before the problems, I will say that the BIOS is updated (F3 Rev.), all drivers are updated (Catalyst 10.5), and all power supply connections are solid. Temperatures are not abnormally high or low. I can game all day with few or no issues. Memory and power supply have been replaced previously as troubleshooting, but problems persist.
1) System will not POST when RAM is installed as dual-channel. The motherboard exhibits continuous beeping, though I am unsure whether it is either short beeping (indicative of a power error) or long beeping (indicative of a graphics error). It occurs when installed as DIMM1&2 or as DIMM 3&4. However, warming up the computer allows system to POST occasionally, though system will not be stable (sporadic BSODs). Installing as single-channel fixes the issue entirely (ie DIMM1&3).
Steps I've taken: Replaced Antec EarthWatts 650 with Antec Basiq 550 Plus, no change. Replaced 4GB (2x2GB) Kingston HyperX T1 2000 MHz with 4GB (2x2GB) A-DATA 1600 MHz, no change. Running RAM at recommended timings and voltage, tried both Auto and Manual settings, no change. MemTest86+ showed no errors with either set of RAM. Again, only thing that fixes issue completely is running in single-channel.
What I'm thinking: Bad processor? I know memory controller is now integrated onto the processor die. Could the motherboard be at fault?
2) Full-screen Flash video causes BSOD or immediate system reboot. BSOD (when it appears) shows error 0x01E (0x00, 0x00, 0x00, 0x00), which points to a hardware fault.
Steps I've taken: Installed latest Flash Player (10.1, even tried RC 7), no change. Re-installed 5770 drivers straight from ATI website after using Driver Cleaner, no change. Disabling hardware acceleration did not help (though it would be a less than ideal solution).
What I'm thinking: Bad video card and/or related to problem 1? I did a bit of Googling, and someone fixed a similar problem by going with Nvidia. There is no similar part to the 5770 that Nvidia currently offers (price, DX11, power consumption), so I'm trying to stick with the 5770. Playing other videos (SD, HD) in Windows Media Player or watching TV (Windows Media Center) do not cause this issue. Again, games work flawlessly.
3) Intermittent loud static from external speakers upon reboot/shutdown (occurs before POST but after OS is shut down). Not a huge issue but I thought it could help pinpoint a problem.
I bought all these parts from a B&M store, and all parts were sealed (they were not returns). I still have about 1 week left to do any returns/exchanges. I've been through the Gigabyte motherboard sticky, and nothing appears to apply to my situation.
Any help or insight is appreciated! Please reply if something I didn't consider crosses your mind. Thanks in advance!
IDE DVD + IDE DVDRW
