Solved
Power consumption of Phenom II 955
Hello everyone. Given the components: Phenom II 955 (oc'ed to 3.6) and, let's say, ATi's 5850. What's the proper Power Supply for this combo? Max fan would be Coolermaster V8. Or any other alternatives that are cheaper but better?
6 answers Last reply Best Answer
More about power consumption phenom
  1. An decent 400W would even do it, but if you want to crossfire that HD5850, go for a quality 650W.
  2. I recommend you a quality 500W PSU with one 8-pin and one 6-pin PCIe connectors.
    If you are thinking about doing 5850CF with two cards, then go for a quality 600W PSU with two 8-pin and two 6-pin PCIe connectors.
    You can find very good options in the PSU Review Database (see my signature)
  3. sure it will be enough? don't forget - it'll be OC'ed to 3.6 (maybe to 3.8, but most probably to 3.6)
  4. Best answer
    The phenom 955 OCed draws 150W, while the HD5850 draws about 130W on load even when you account 50W from everything else, its just 330W.
    That is exactly what i wanted to know. thank you.
  6. Best answer selected by miha2.
Power Supplies Power Consumption Phenom Components
