1)
CPU: AMD FX-8150 Zambezi 3.6GHz Socket AM3+
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133
GPU: EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16
MOBO: ASUS M5A97 EVO AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
OS: Windows 7 64-bit
Hard Drive: (old) Western Digital WD2500KS. (I believe it's something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701)
Brand new install of Windows 7 64-bit and it would freeze every few seconds or so. Changed it in the bios as it was default set to AHCI and once I put it to IDE, it now runs smoothly.
So I was googling the problem and some people said to reinstall Windows 7 as AHCI. I'm a little confused though, since the BIOS was already defaulted as AHCI, does that mean I installed it as AHCI too? I would like to switch over to AHCI but not sure how. Is my HD not capable of it?
2) Is AHCI that much faster than IDE that it's worth a reinstall of Windows?
3) My motherboard has:
6 x SATA 6Gb/s ports with RAID 0,1,5 and 10 support
2 x eSATA 3Gb/s ports
Which ports should I plug my hard drive into?
I plugged my HD into the "2 x eSATA 3Gb/s" ports. Would I be getting 6Gb/s speeds if I plugged it into the "6 x SATA 6Gb/s ports with RAID 0,1,5 and 10 support"? Or is my hard drive too old? I figured I'm not using RAID so don't plug it in there?
Thank you so much for any help
