Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > First build help. (Non-gamer)
Forum Systems : New Build First build help. (Non-gamer)
Been checking the forum out for a few days now and after reading tons of information, I would like some opinions on what I am thinking for my first build.
I am not a gamer, but would like a system that could do some basic gaming if I decided to get into it in the near future.
This build will be a general use machine for web surfing, light video and photo editing and some MS Office work.
I need something that will be robust and give me at least 5 years.
Here goes:
APPROXIMATE PURCHASE DATE: 2 Weeks
BUDGET RANGE: $1,000 - $1,200
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: light video and photo editing, MS Office, Web Surfing, Research Gaming
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg, tigerdirect, amazon
PARTS PREFERENCES: None
OVERCLOCKING: Maybe as I learn a little more
SLI OR CROSSFIRE: Maybe, if necessary down the road.
Rosewill Blackbone Black Steel ATX Mid Tower Computer Case
MSI NF980-G65 AM3 NVIDIA nForce 980a SLI HDMI ATX AMD Motherboard
Thermaltake TR2 TRX-750M 750W ATX 12V v2.3/EPS 12V v2.91 80 PLUS Certified Modular Active PFC Power Supply
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Model HDZ965FBGMBOX
Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler
OCZ AMB Black Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II MLC Internal Solid State Drive
(2) Samsung Spinpoint F3 HD103SJ 1TB 7200RPM SATA 3.0Gb/s 3.5" Internal Hard Drive RAID 0
Lite-on 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
Lite-on Black 4X Bluray Reader SATA Model iHOS104-06 - OEM
Microsoft Windows 7 Home Premium 64-bit
What says you? Am I overbuilt for my needs?
Reply to BaSiCEvil
Stay away from Roswell.
Get a better motherboard and get a cheap graphics card.
I would reallly go with an i5 750 build instead. The only reason I would go AMD is if I was going to get a 1055T or 1090T.
Get a better known psu, and you only need 400-500w.
The cpu heatsink you selected isn't that good. The CM hyper 212+ performs well and only costs $30 shipped.
+1 for that Intel SSD
------------------------------ i7 875k, 40gb Kingston SSD / 500gb barracuda,
Biostar XE CFX/SLI, Evga 460 gtx 1gb SC EE
2x2gb OCZ DDR3 1600, Corsair 650TX, Win 7 64
Reply to cory1234
Whoa some strange calls u made:
1. Non gaming build and 3-way SLI board :P Get the 880G with SATA 6GB/s and USB 3.0
2. Understand u want to have some room in case discrete but 750W a bit over hehe
3. I'd rather go with the new Sandforce based SSD
4. For about $938 AR
http://i137.photobucket.com/albums/q205/batuchka/Untitled-165.jpg
Message edited by batuchka on 06-12-2010 at 10:52:01 PM
Reply to batuchka
I forgot to mention that I need the case to fit in a smaller opening in a desk that I just bought. 17.5" H x 10"W x 18" D MAXIMUM
Reply to BaSiCEvil
This is a good combo deal for your build:
OCZ ModXStream Pro 500W ATX Modular Power Supply + Sony Optiarc Black 24X DVD Burner: $35
http://slickdeals.net/forums/showthread.php?t=2074646
Reply to cory1234
Thanks for the suggestions and help.
Do you guys think that I should consider a 1055T over the 955BE?
Reply to BaSiCEvil
Just thought of something that I forgot that may change some earlier suggestions.
In our new apartment, our 42" Plasma TV is about 8 feet away from the computer desk and I would like the ability to play movies from the computer to the plasma via HDMI.
While we are watching movies on the plasma, I would still like to have the ability to use the computer.
A friend suggested that I need a video card with "dual" cababilities.
Can someone comment on this?
Thanks.
Reply to BaSiCEvil
Decided to go in a completely different direction with this...
After HP pissing me off and telling me that they will not sell to the Bahamas from their website, I decided to go the i5 route based off what I had spec'd out from them.
I need suggestions on Memory. I'm thinking 8GB.
Tell me what you think...
COOLER MASTER Gladiator 600 RC-600-KKN1-GP Black SECC Body ; Mesh Front bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811119206
ASUS P7H55-M PRO
http://www.newegg.com/Product/Prod [...] 6813131623
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115215
CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Prod [...] 6817139003
SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Card
http://www.newegg.com/Product/Prod [...] 6814102874
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152185
LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM
http://www.newegg.com/Product/Prod [...] 6827106325
LITE-ON Black 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Prod [...] 6827106289
Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate
http://www.newegg.com/Product/Prod [...] 6820223109
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Prod [...] 6832116758
I think that covers it all, except for RAM. Help a brother out, by recommending some memory. :D
Message edited by BaSiCEvil on 06-22-2010 at 03:02:07 AM
Reply to BaSiCEvil
You don't need the i5 for "light video and photo editing, MS Office, Web Surfing, Research Gaming", you should get a cheaper CPU and a better video card.
You don't need the CD/DVD-ROM if you buy a CD/DVD burner.
GIGABYTE GA-785GMT-USB3
http://www.newegg.com/Product/Prod [...] 6813128432
AMD Phenom II X4 945 + Antec Mini P180 White Steel MicroATX Mini Tower
http://www.newegg.com/Product/Comb [...] mbo.410669
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Prod [...] 6820231189
SAMSUNG 24X DVD+R 8X DVD+RW
http://www.newegg.com/Product/Prod [...] 6827151216
SAPPHIRE Vapor-X 100284VXL Radeon HD 5750
http://www.newegg.com/Product/Prod [...] 6814102865
Scythe SCSK-1100 100mm Shuriken Rev. B
http://www.newegg.com/Product/Prod [...] 6835185097
SeaSonic S12II 430B 430W ATX12V V2.3/EPS12V 80 PLUS BRONZE
http://www.newegg.com/Product/Prod [...] 6817151074
$854.90
Reply to mosox
I forgot to put in my last post that I added to my needs for this system.
Seeing that my entertainment center with 42" plasma is less than 6 feet away from my computer desk, I decided that I would also use the new build as a media PC and send HD content to the Plasma as a seperate monitor, thus the need for a GPU that could handle both at the same time.
Does that change any of your recommendations?
Message edited by BaSiCEvil on 06-23-2010 at 07:43:04 PM
Reply to BaSiCEvil
Looking for critiques on my final decision...
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813131621
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115214
I am planning on pulling the trigger in about an hour or so.
Think that this will last me the long haul?
Reply to BaSiCEvil
There are 1828 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 46 minutes ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
