I have a question about the system panel header. My MoBo has a system panel header with: PLED + and - , HDLED + and - , PWRBTN # with a ground across from it, and RESET # with a ground across from it.
It also has a power LED header (separate from the system panel header) which is 3 pin and has: PLED + for 2 pins and PLED - for the other.
My case cables have a 1-pin power led + and 1 pin power led -. Which header do these plug into (power LED or system panel, what configuration)? Also my HDDLED has a red and black wire--black is negative? Power SW has a green and black cable--black is ground? Reset switch has a blue and white cable--white is ground?
My fans have peripheral power connectors so I don't need to worry about using the fan power headers on the motherboard as long as each fan is plugged into something for power? (this excludes cpu fan of course which is plugged into the correct header)
Thanks for any help!
