How to use both wired and wireless connection on a laptop?
schlengerich
Hello,
I have an laptop and a desktop , my laptop has both wired and wireless connections,
I want to use my laptop wireless connection to connect to the internet/WAN ,and the lan connection to connect to my LAN at the same time.
The problem is when I plug my LAN wire into the laptop , my laptop wireless connection stops!!
what should I do to prevent this from happening, I am on win server 2003 SP1, yes its old, but I use RIS…
Thanks in advance
Go to Start->Run, type "ncpa.cpl" (no quotes), and hit enter. Select Advanced->Advanced Settings->Connections and make sure the wireless connection is listed FIRST. If you need to reorder, do so and reboot.
schlengerich
Hey
I´m running Server 2003, the problem is when I plug my LAN wire into the laptop , my laptop wireless connection stops. I have a static IP on the wired netcard.
Stops as in the wireless connection is literally dropped, Windows reports a loss of wireless signal and says you’re no longer connected? Or stops as in the wireless connection remains active, no indication the wireless signal has been dropped, but any attempt to access the Internet doesn't work, it returns website not found, can't load website, that sort of thing?
You have to understand that ppl often use ambiguous terminology and we try to read between the lines to determine their intent, or make a first best guess. But sometimes we guess wrong.
So now you need to be absolutely precise in describing what "my laptop wireless connection stops" means.
schlengerich
Hi,
It´s okay
when I plug my LAN wire into the laptop, my laptop wireless connection stops, or it is dropped, working ( a red cross over the computer sign in the taskbar) and there is no internet connection.
I want you to do what’s described below TWICE. Once when only the wireless connection to the Internet is established and working (and obviously the LAN side is NOT yet connected). Then plug in the LAN connection, let the problem occur, and do it again. IOW, I want to see the results of IPCONFIG both before and after the problem occurs so I can contrast them.
Go to Start->Run, type "cmd" (no quotes), and hit enter. In the command window, type "ipconfig /all > temp.txt" (no quotes) and post the file's contents here.
schlengerich
wireless is established and working.
Windows IP Configuration
Host Name . . . . . . . . . . . . : storm-e07vvluvy
Primary Dns Suffix . . . . . . . : test.local
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : test.local
LSE-JON.local
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) 82566MM Gigabit Network Connection
Physical Address. . . . . . . . . : 00-17-A4-EA-59-B6
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Ethernet adapter WAN-Wireless Network Connection:
Connection-specific DNS Suffix . : LSE-JON.local
Description . . . . . . . . . . . : Intel(R) Wireless WiFi Link 4965AGN
Physical Address. . . . . . . . . : 00-13-E8-CE-F7-1D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.100.4
Default Gateway . . . . . . . . . : 192.168.100.1
DHCP Server . . . . . . . . . . . : 192.168.100.1
DNS Servers . . . . . . . . . . . : 192.168.100.1
Lease Obtained. . . . . . . . . . : 8. marts 2010 20:58:16
Lease Expires . . . . . . . . . . : 9. marts 2010 00:58:16
WIRE
IP Address. . . . . . . . . . . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
DHCP Server . . . . . . . . . . . : 255.255.255.255
Okay?
Go into the TCP/IP configuration for the LAN connection and remove the default gateway and dns references (192.168.0.1). I want those to be BLANK. All it should have is 192.168.0.1 for the IP address and 255.255.255.0 for the subnet mask. That's it. Save the changes, reboot, and try again.
schlengerich
You know at I´m using the laptop as a server to connect WAN(wireless) and my LAN(wire)?
Therefor I have a static IP, using DHCP for my LAN.
Wireless
IP Routing Enabled. . . . . . . . : Yes
LSE-JON.local
Lease Obtained. . . . . . . . . . : 8. marts 2010 21:28:19
Lease Expires . . . . . . . . . . : 9. marts 2010 01:28:19
Wire
Autoconfiguration IP Address. . . : 169.254.218.112
Subnet Mask . . . . . . . . . . . : 255.255.0.0
You originally had DHCP Enabled = OFF on the LAN connection. I then asked you to get rid of the default gateway and dns server on that LAN connection and only specify the IP address (192.168.0.1) and subnet mask (255.255.255.0). Instead you enabled DHCP on the LAN connection. Why?
schlengerich
Wireless
LSE-JON.local
Lease Obtained. . . . . . . . . . : 8. marts 2010 22:07:27
Lease Expires . . . . . . . . . . : 9. marts 2010 02:07:27
Wire
But I can´t see why it should a IP issu....?
Earlier I asked you to make sure the wireless connection was listed first under Network Connections->Advanced->Advanced Settings->Connections. Is it? If not, do it now.
Oh, well, I haven't been on Windows 2003 server in ages.
I'm just wondering... is it possible there's something on that machine that is perhaps disabling the wireless connection as say, a security measure? Say to prevent “cross contamination” (for lack of a better term)? Maybe some anti-virus or anti-malware software? Maybe even a network configuration option in W2K3? Being a server it may have more stringent security measures than say a Windows 7 client.
