Acer netbook battery advice
Hello,
If I use my Acer Netbook only every few weeks--should I remove the battery--or leave it in place?
1 answer Last reply
More about acer netbook battery advice
  1. Leave it in-place - do not remove the battery! The same applies to laptops too.
    Battery usage is ok when you are away from an AC outlet - if a 110 Volt AC outlet is available, use the AC adapter and the battery will gradually get fully charged as you are using the computer.
    Your Netbook has a Lithium battery, and Lithium batteries will have a longer life if they are between 50% and 100% charged. It is not advisable to run down (flatten) this battery frequently.
Battery Acer Netbooks Components
