No signal on monitor while pc is running
  • Graphics Cards
  • Power Supplies
  • Monitors
  • Splash Screen
  • Windows XP
  • Graphics
Anonymous
a b U Graphics card
a b ) Power supply
a b C Monitor
May 7, 2010 10:16:30 PM
Hello,
I installed a new video card and new power supply, but after the XP splash screen I am getting "no sognal" and the monitor goes into sleep mode.
More about : signal monitor running
a b U Graphics card
a b C Monitor
May 8, 2010 1:05:03 AM
sounds like its trying to boot to an unsupported resolution.
make sure you remove all the old drivers for the old video card, then boot into safe mode to install the new drivers. then you can set a resolution compatible with the monitor.
EDIT: and to point out an obvious one in case you missed it; you have plugged the monitor into the new card right? not the onboard video card?
m
l
